Do the new bikes use a true o-ring and not the flat style o-ring? This is what my 14 takes
Originally Posted by Gliden
That's is what my 2019 takes. I wouldnt mess with getting an aftermarket o ring.
Here's how it goes:
All Milwaukee 8 and last year Twin Cam baggers use that flat style o-ring. Those bikes are equipped with a 7.75" dia derby cover.
With the exception of the last model year baggers, all Twin Cams came with the 7.25" dia derby cover. Some of those derby covers have the gasket channel and use the flat o-ring (same p/n as the Milwaukee 8 version: 17369-06), while others use a full disk style gasket (HD p/n 25416-99C). If there is a hard and fast way of knowing if a Twin Cam came from the factory with the flat o-ring vs the full disk gasket, I don't know what it is.
Twin Cam outer primaries are compatible with either type gasket, so if you open yours up and find the flat gasket, but want to convert to the flat o-ring (and have a derby cover with the required gasket channel), you can. Or vice versa.
Originally Posted by F150HD
you mean for derby cover. Like lp, have never changed mine once either.
Originally Posted by Navy Mustang
I replace mine at every primary oil change.
My $0.02 on that: AFAIK, the gasket on my '90 Electra Glide (the gasket channel on Shovels and Evos is in the outer primary) is still the same one that came from the factory, and I've never had a problem with leaks. That said, for the cost of a gasket, changing it is cheap insurance. The packaging from HD on the flat o-ring gasket says it is for "1k / 5k / 10k" service.
