2008 FLHX swingarm pivot shaft
Old Sep 15, 2023 | 06:18 AM
Jrok's Avatar
Jrok
3rd Gear
Default 2008 FLHX swingarm pivot shaft
What is the tolerance for the pivot shaft in the transmission? And swingarm? Not together, one at a time.
Should the shaft be tight? I can wiggle the shaft very little as in a few 1000s. Normal?
Anyone know the measurements of the shaft? And bores?
Old Sep 15, 2023 | 07:57 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I’ve an 04, and there are no specifications in my factory manual for those values.
I can tell you the shaft and transmission case has to have some clearance to easily fit, and most crucially, to get the belt sprockets into alignment.
The swing arm should have as minimal a clearance as possible, to prevent the swing arm from deflecting, which turns the rear wheel. This play is often hidden by belt tension.
Old Sep 15, 2023 | 03:19 PM
decencyxdefied's Avatar
decencyxdefied
I can't take your name seriously lol
Jrok
Sep 12, 2023 05:38 PM
deeblues
Jul 23, 2013 08:47 PM
FLHXJewel
Welcome Area Only
14
May 3, 2013 09:19 AM
CigarCritic
Motorcycles For Sale
Aug 8, 2010 08:32 PM
menace
Welcome Area Only
15
Apr 23, 2008 08:52 PM
