I have a 2006 Ultra Classic which will not crakn. I haven't ridden the bike since Nov 4 due to weather, etc. Running fine then. I have had a trickle charler on it continuously since then which indicates the battery is charger. Went to crank it today for a ride and it's completely dead regardless that the charder indicated good to go. I had a new battery installed in 2021. I'm sure you can't use a car charger or even jump it off either. What should I do? Hate to be so dumb but I've always been a rider and not a mechanic.
Any lights come on?
Kill switch in off position?
Security on?
Fuses good?
Battery connections good? Probably need to be cleaned up anyway.
No reason you can`t jump it. I rather suspect your battery is toast
This above highlighted...Depending on how long battery was left in a discharged state, it very well may be toast and unchargable...it could still show green on the charger and still be bad...have it load tested...
