Hey guys, I have a 2001 road king classic with the wire spoke wheels, I can get a stock set of wheels from a 2012 street glide for a good price, my question is wheel these wheels be a direct bolt on? I know the rear tire will be wider but can I use a narrower tire to make it work? If so, what size tire is recommended? Thanks for any info
The front wheel can fit with an axle change. The rear won't as it's setup for a wider rear tire, narrow belt, same axle problem but the newer axle won't fit the swingarm.. I like street glide wheels, Had them on my 07 EGC and had them on a 02 RK classic.. Used 09-up 18 inch fronts. You can use street glide rears up to 08 but will have to replace the bearings and spacer in the wheel.. The early TC (except 99) disks bolt on.
