BUILDING A 103 "HELP ME MOTOR-HEADS"
Old 11-08-2007, 07:24 PM
asuperheat's Avatar
asuperheat
asuperheat is offline
Default RE: BUILDING A 103 "HELP ME MOTOR-HEADS"
Think you should look into the H.Q. 107 kit I dont think you have to go intothe cases just top end and cams if I remeber right.
Old 11-08-2007, 07:25 PM
PhilM's Avatar
PhilM
PhilM is offline
ORIGINAL: genedjr
No, the 96-103 is the same as 88-95.
And, the 96-110 is the same as the 88-103.
Interesting.
...gene
I'm not totally sure that's completely accurate.
In a Twin Cam:
96" = 4.375" stroke x 3.75" bore
103 = 4.375 x 3.875
110 = 4.375 x 4.0
113 = 4.375 x 4.060
After market 107" = 4.375 x 3.93x
Anything larger than the 107" requires case boring to support the larger spigots on the cylinders... This means spilt the case!
If you're doing that.. you may as well go for the 113, or even the 120 like ..... someone I know.
Old 11-08-2007, 08:23 PM
Road Hawg's Avatar
Road Hawg
Road Hawg is offline
Lots of good information on this forum, I appreciate all the input, it certainly helps making an informed decision. I thinkI will talk to the guys at HQ next week. I will ask about the 107, but it seems as if you would have to split the cases for a 3.93 stroke, or you might be pushing the envelope. I put 20-30k a year on my bike so I definitely do not want to compromise the dependability, it seems like a fine line between performance and dependability. I'll be checking the forum frequently this week end to gather as much information as I can before next week.. Thanks Guys I appreciate your time and advise....
Old 11-08-2007, 09:23 PM
PhilM's Avatar
PhilM
PhilM is offline
In a 107" TC build, 3.93x is bore, not stroke and the will bolt on w/o need for splitting the cases. The stock stroke on a 2007 Twin Cam is 4.375".
Old 11-09-2007, 08:56 AM
Road Hawg's Avatar
Road Hawg
[quote]ORIGINAL: PhilM
Thanks Phil, I will check out the 107 for sure now. Thanks again...
Drumlord
EVO
11
10-24-2018 08:10 AM
shortleg
11-30-2011 04:46 PM
Sadthorn
Exhaust System Topics
18
01-22-2011 08:15 AM
6165hd
28
11-02-2010 10:00 PM
Road Hawg
11-14-2007 04:32 PM
Quick Reply: BUILDING A 103 "HELP ME MOTOR-HEADS"
