"DIY MODS" and TRICKS to SAVE $$$$$$
  #2021
Old 11-22-2017, 09:33 AM
V-8's Avatar
V-8
V-8 is offline
Originally Posted by Heloguy
Not for nothing, but, I ordered and installed this. The hardest part was trying to figure out exactly where i wanted to mount it.
Works great!
https://www.ebay.com/itm/HD-SECURITY....c100290.m3507
Buzzbait - I found this on Amazon - as far as I can tell it's the same one. Works great!
Megatronix - PZ9 - 12Volt 110db One Tone Piezo Alarm Siren
Amazon Amazon
  #2022
Old 11-22-2017, 09:36 AM
V-8's Avatar
V-8
V-8 is offline
Default Shifter Extension
  #2023
Old 11-22-2017, 09:40 AM
V-8's Avatar
V-8
V-8 is offline
Quick idea for a shifter extension - I was having trouble fitting my toe under the shifter.
2" longer bolt, a piece of metal pipe (painted wrinkle black) with a nylon bearing inside to keep it from moving.
It was about $6 at the hardware store.
head (04-15-2018)
  #2024
Old 11-22-2017, 10:48 AM
Rahlstin's Avatar
Rahlstin
Rahlstin is offline
Default Plugging Saddle bag holes when washing off bike
16-Limited
Not really a mod but when I wash my saddle bags off the bike I plug the mounting holes with those squishable foam ear plugs to keep water out.
The following 5 users liked this post by Rahlstin:
BobRed0965 (11-29-2017), Damo222 (11-22-2017), Frank the Real Biker (11-22-2017), johnanderson (05-15-2022), seewyte (04-11-2022)
  #2025
Old 11-23-2017, 09:23 AM
itsmf's Avatar
itsmf
itsmf is online now
kuriakin sells peg extensions
  #2026
Old 11-25-2017, 02:56 AM
TEN4T2's Avatar
TEN4T2
TEN4T2 is offline
4th Gear
Default Bag bottoms
To keep from scratching the bottoms of the saddle bags pick up some of those self adhesive felt squares you see under paper weights or lamps. You can find them at Lowes or Home Depot. They cost about $2.00 a package. Wipe down the corners on the bottom of the saddle bags with a cleaner. (I like 92% rubbing alcohol.) Stick a felt pad on each corner and let it set up. Then if you need to pull a bag off and set it on concrete or small gravel the felt pads get it, not your paint.
The following 4 users liked this post by TEN4T2:
Damo222 (11-29-2017), Frank the Real Biker (11-25-2017), Loki255 (12-04-2017), Mat0722 (05-02-2018)
  #2027
Old 11-25-2017, 03:51 AM
cmtaylor's Avatar
cmtaylor
cmtaylor is offline
I did similar but instead of felt used the 3M brand clear plastic/rubber feet instead...
  #2028
Old 11-25-2017, 07:17 AM
Frank the Real Biker's Avatar
Frank the Real Biker is offline
That's a good idea. I'm cheap, so I did something similar with stuff I had laying around in my shop already. I cut out a bunch of circles and shapes from an old truck tire inner tube and glued 'em to the bottom using 3M emblem adhesive after a good cleaning with the above mentioned alcohol. Totally impervious to the elements. Don't need to worry about rain or dirt causing them to come loose.
  #2029
Old 12-02-2017, 06:53 AM
Hate Work's Avatar
Hate Work
Hate Work is offline
I had some leftover 3M clear bumper protection film. Just covered the entire bottom. You can't see it but it's thick enough to do the job. But seriously, I must be ****, as no one sees the underside unless I'm dragging the floorboards or have dumped it....
  #2030
Old 12-02-2017, 07:32 AM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,608 Likes on 2,863 Posts
I can sum this up in 2 words
I'm not. lol
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
