Trimming SG Antenna
RE: Trimming SG Antenna
ORIGINAL: zopi
I'd recommend gettin one of the shorter rubber antennas...cutting an antenna changes it's resonant wavelegnth and will affect reception...
The short rubber antennas contain a loading coil that effectively increases their length.
This way you are not disturbing the ideal (electrical) wavelength the radio needs for good reception.
Cutting my antenna has had no adverse effects on reception, even in mountainous, twisty area's near my home. If your going to replace the antenna with a shorter rubber one, what do you have to lose by cutting it?
The only adverse effect I have read on cutting the stock whip is CB operation, which I don't use.
