True duals, Yes or no?
OK Guys here we go again, Spring is coming, and its about time to get the bike out. Ive got a 06 RG and its not loud enough, plus it lacks a little power, so I want to put on a new set of slip ons, but will they give me any more power?, or do I need to put on true duals with a sert and air cleaner? And what kind of air cleaner? should I stay with the stock cover and run a k&n, or change the whole thing to somthing different? I do alot of riding with the wife also, if that makes a diff.
RE: True duals, Yes or no?
http://www.google.com/search?q=dobec...mp;rlz=1I7GGIHIf you are going to the air cleaner check out A Ness big sucker its a hard one to beat...You will also have to add some fuel to the old girl so I would advise the Dobeck TFI as you can tune it and don't have to mess with the computer and different downloads... True duals will give you a better sound but will do very little for performance...Good luck what ever you do....
Jer
Jer
I just ordered the supertrapp 2 into 1 for my flh. The true duals look better and sound good but do nothing for performance unless you do a big inch build. Eastern is having a sale on exhaust systems as we speak! I'll be selling a set of supertrapp performance se slipons next week. Do some kind of fuel management when you do your other changes.
2 into 1's are better for performance, but i dont like the look of the left side with a pipe there. i went with rinehart td and love the sound. i also did SE air cleaner and have SERT but it isnt installed yet. i think it runs good and hopefully the SERT will help out even more.
True duals, pros: Appearance (subjective), stereo sound, less heat on right leg (no crossover). Cons: Power reduction, cost.
For best power result consider a 2-into-1, but if you want the power gain without the cost, consider Fuel Moto's custom solution for stock head pipes (http://fuelmotousa.com/rush_fuelmoto). Noise is moderate, power excellent with these custom baffles.
