air shocks
Old Jan 25, 2008 | 01:22 AM
chuckk01's Avatar
chuckk01
Default air shocks
I just bought a 2006 street glide and it's my first harley. What air pressure should my air shocks be at and how often should I check them.
Old Jan 25, 2008 | 01:45 AM
Big Tom's Avatar
Big Tom
Default RE: air shocks
Really the pressure depends on weight of rider or riders combined. I am 380 lbs. so I set mine between 25 and 30 it's something you kind of need to play with to see what you like. As far as checking the air pressure I do it before I go on a long ride or once a week anyways I have found that my bike leaks a little air over the course of a week. Hope this helps TOM
Old Jan 25, 2008 | 01:54 AM
DI75's Avatar
DI75
Good advice!!
Old Jan 25, 2008 | 02:28 AM
reeac's Avatar
reeac
Check the owners manual and go from there. I made five settings before I found the one I liked.
Old Jan 25, 2008 | 02:33 AM
SoCal_Pappy's Avatar
SoCal_Pappy
If this is your FIRST HARLEY then you should spend the time to read the owners Manual & Pick-up the Service Manual also...
Old Jan 25, 2008 | 11:46 AM
chuckk01's Avatar
chuckk01
Thanks, got the owners manual now I'll buy the service manual.
Old Jan 25, 2008 | 12:37 PM
Thirdup's Avatar
Thirdup
Btw, I'd suggest a hand pump (either the HD or one of the others designed for the task). It's a pretty tight system and you can blow a line or seal using compressed air at a station.
I run around 25lbs on trips (one-up with about 100lbs of gear). Mine tends to bleed off pressure after about a week, so I now check it regularly. I've heard mechanics say that you shouldn't let it run at zero pressure for too long...something about it allowing the lubricant in the system to escape.
ymmv
Old Jan 25, 2008 | 01:47 PM
Flying Horse's Avatar
Flying Horse
Check pressure regularly as they will loose pressure.
I ride 2 up and have them set at 18-20 lbs but it depends on what you think is comfortable and what weight you're moving around.
Get the HD hand pump, use nothing else.
dvldg 66
Air Suspensions
Sep 27, 2013 01:41 PM
carlo
18
Apr 15, 2009 09:41 PM
hardyf111
Jan 11, 2009 01:24 PM
Thunderchild
Mar 17, 2008 10:52 AM
fiddlinfool77
Jun 9, 2007 08:50 AM
