Duhh they buy book and then still ask?????
If the book which was written for and by Harley Davidson says 38 oz
then use 38oz.
32oz is 6 oz short, will it make a difference???? who knows!
then use 38oz.
Did you not get enough attention as a kid choo? I think I'm starting to see why you're called choo choo.. You'd drive that train right over your best friend... Dick!
From reading the service manual for my 04 RK, and it says basically the same thing, I interpret that it means "Use 38 ounces of this fluid, which is part # xxxxxxx for quart bottles and part #xxxxxx for gallon bottles."
I think 38oz. is capacity. I don't think you can get all 38 oz. out just draining. If you had to remove the primary cover for any reason then you would need the full 38 oz.
