aftermarket tour pack
i am tired of searchin for an answer. i want to get either the mutaza tour pack or somthing similar to that. what do i need to attach this to my 2007 road king classic. either quick releaseor permanentattachment. anybody have this setup and what did you do?
thank you. |
RE: aftermarket tour pack
I've got the Mahatzu (sp?) aftermarket tour pac and it works quite well with either a permanent or detachable HD mount. I used the detachable mount and have the bike setup so I can use a sissy bar/rack combo around town and the tourpac on trips. The quality isn't as good as a HD tourpac, but it works just fine for my use.
when i had that matzu tour pak i used the harley two-up quick detach mount hardware.....i think it was around $150 from zanottis.
i have the detachable backrest now. is that what i need to get for this to work. just the hardware?i also want to be able to change from the backrest tot he pak at any given time
http://www.harley-davidson.com/gma/g...bmLocale=en_US
There ya go. this is what you need to swap back and forth |
ORIGINAL: Mathews2 http://www.harley-davidson.com/gma/g...bmLocale=en_US There ya go. this is what you need to swap back and forth anybody try this pack http://cgi.ebay.com/ebaymotors/HD-Ha...QQcmdZViewItem it looks the same as mutuza but a little differant |
I used the HD detatchable rack.The mutuzadoesn't look as good as the Harley Davidson TP but it works just fine. I like mine.
http://williamacarr.smugmug.com/phot...48_jmjnd-M.jpg |
you will also need to rear docking points, your detachable backrest mounts to the forward ones.
Heres an old thread with some good info,I have been saving it cause I wanted to do something also. Today I just ordered the HD Tour Pak with all the goodies.
https://www.hdforums.com/m_2582928/m...tm.htm#2582928 |
ORIGINAL: twilliams you will also need to rear docking points, your detachable backrest mounts to the forward ones. |
© 2024 MH Sub I, LLC dba Internet Brands
