Exhaust Shield Upgrade - Nice!
thanks for the quick reply - so you just unscrew the old clamp with the screw driver and then does that metal ringe completely unhook or release? With the new one, is the metal loop open and then you insert it in the other side and tighten down the screw?
I just wantto make sure I do not have to take off the pipe or get myself into a situation where they say 5 minutes but it ends up being a bigger project.
gotcha - you bring up a good point - I will have to take a look at the bike tonight because the guy I bought it from put on a Bassani True Dual system, so I am assuming the heat shields that are on there may not be stock and were part of that system.
If thats the case, is it better to go with the Kur bridge the gap shield?
