Need HELP!!!!
Old Aug 26, 2008 | 11:45 AM
harley-jones's Avatar
harley-jones
Default Need HELP!!!!
Started up my 08 SG to warm up and everything was fine and all of a sudden the tach went to zerror, and now most of the icons are not working (fuel pressure, and the abs light is on and not blinking.
I checked the fuses and all are o.k.
I did notice in the fuse block there is a P&A IGN that says 2A Max.
It had a 15 amp fuse in it.
Anyone have any Ideas?
Call dealer and he just said bring it in. He's 2 1/2hours away so if there is something I can reset or check that woud be great.
Thanks
Old Aug 26, 2008 | 01:08 PM
harley-jones
I also just noticed the little security key is also not flashing. The turn signals still flash when you turn off the switch.
I am a little upset as I have only had this bike for less than a week.
I rode my FatBoy for 10 years and never had a problem. Oh well just my luck and it's under Warranty.
Old Aug 26, 2008 | 01:28 PM
sknyfats's Avatar
sknyfats
I'll just take a stab at this - no real SG experience for this type of situation - but I wonder what would happen if you disconnected the batter for a few minutes? Might reset something that tripped? Or maybe there's a loose wire/connection somewhere?
Old Aug 26, 2008 | 01:38 PM
kjmorgan's Avatar
kjmorgan
Check battery connections, pull up error codes.Did you just wash it or ride in heavy rain? That's it, I'm out of ideas for now.
Old Aug 26, 2008 | 02:01 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Recently hit a bump in the road and lost the back light on speedo, speedo froze at 45, lost tach, and lost odo on my 03 Heritage. Check engine and security light worked normal.
Had a broken ground wire under the seat near battery positive terminal. Cleaned and spliced it. All good now.
Pull the seat and do a "wiggle" test to see if it comes and goes.
Old Aug 26, 2008 | 02:05 PM
QIKLUV's Avatar
QIKLUV
turn or wigglr your power selector on the tree. some have been having trouble there from vibration/corosion. seen 2 like that so far
Old Aug 26, 2008 | 02:59 PM
jerseyjeff62's Avatar
jerseyjeff62
less than a week!!! call your dealer, have them come out and pickup your dead bike!
Old Aug 26, 2008 | 03:34 PM
harley-jones
Well..........I moved the bike about 10ft and everything started to work. Now I don't know what to think. Weird....... weird!!!
Thanks for your help, I will let you know if it happens again.
Old Oct 1, 2008 | 04:44 PM
MeanMorningJoe's Avatar
MeanMorningJoe
Got the following from another list on how to get the error codes to display. I have not tried this but what the hell...
ECM CODES
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word "none" will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
2007 DTC CODES
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0134 Front 02 Sensor Open
P0154 Rear 02 Sensor Open
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
Old Oct 1, 2008 | 08:15 PM
tallboy56's Avatar
tallboy56
Don't know but it sounds like a bad connection somewhere...was that 15 amp fuse in the 2amp slot from the start? That could cause real trouble if that circuit got overloaded somehow...
