ZUMO550 - Sharing
Old Oct 18, 2008 | 07:18 PM
iclick's Avatar
iclick
Originally Posted by Wecroft
If he hasn't got a problem with volume while playing CDs then I will garantee the problem is the master volume on the Zumo as it will only let the bike radio play as loud as the master is set. If he's playing it through the radio, he will not need to fiddle with MP3 Gain or the boosters that are out there. It should blow the wax out of his ears even at 95 MPH.
That's a point I should've mentioned above, to make sure the Zumo's master volume is set to 100%. It is at 70% by default, IIRC. Even set to 100% the volume wasn't acceptable on my unit, and with MP3Gain it is now only passable, and I would like more. I will likely use the HD head unit's MP3 player most of the time, then switch to the Zumo's player when I want the voice directions to be heard through the speakers.
Old Oct 18, 2008 | 07:59 PM
lviguy's Avatar
lviguy
Check out the ride planner on the HD site. It now allows export of routes in the Zumo format so you can transfer them to your device. Many folks share their routes.
Old Oct 18, 2008 | 08:46 PM
tatt2zzz's Avatar
tatt2zzz
You mentioned that it plugged into the AUX port on the radio. Does it come with the wire or did you buy it as an accessory? Do the directions play through the radio?
Old Oct 18, 2008 | 09:11 PM
Wecroft's Avatar
Wecroft
The answer is YES. When you plug the patch cord into the AUX port, the radio will default to the aux mode. The navigation prompts and MP3 player that is built into the Zumo will play thru the radio to the speakers or the headset, whichever you choose with the fairing switch. If you don't want to listen to the output of the Zumo you simply select the radio function you want, but then the prompts will not be heard.
With the Zumo master volume set to max you use the handlebar volume switch to control it. There's also another volume control to set different percentages of the total volume separately for navigation prompts and MP3s. When a prompt is given, the MP3 is silenced and the prompt is heard. if you want it to be softer or louder than the music, you just set the differential volume control for the result you want.
Most complaints about insufficiant volume are a result of the operator having either the master volume or the differential volume control set too low. The radio can only amplify what is fed to it.
The wire is available at any electronics store. It's a stereo patch cord with a 1/8" jack on each end and costs about $5.
Old Oct 19, 2008 | 05:01 AM
jcbpa's Avatar
jcbpa
Great thread! I'm going to download some of the info, My Zumo is great, but Friday it went to sleep for about 10 minutes? Anyone know how to reset it? I kept pushing buttons... All of sudden it woke up.
Old Feb 5, 2009 | 10:01 AM
Woodchuck's Avatar
Woodchuck
Please help a non-techie who is ready to pull the trigger and get a Zumo 550.
I've searched and it appears I can get audible directions by patching between the 550 and the radio on my '07 FLHTC. I don't care to listen to the radio or CDs. Does or can the patch between the unit and the stereo system mute the radio except for directions?
I plan on wiring the gps to the spare spade connector on the headlight circuit and ground it to the radio ground. Is there an easy way to install battery tender style connectors so that I could swap it from one bike to another? The other bike doesn't have a cigarette lighter or a radio.
I'm not into blue tooth, talking on a cell phone while going down the road or listening to an MP3 player or whatever. I'm getting the 550 because of its other features especially the accessories necessary to use it in the truck also.
Old Feb 5, 2009 | 10:41 AM
rochkes's Avatar
rochkes
The patch cord is plugged into the aux port on the stereo. You will only recieve navigation prompts when you are in aux mode. If you are in am/fm mode, you will not hear the navigation prompts.
If I were planning on switching the zumo back and forth between two bikes, I would buy a second motorcylce mount and leave a mount on each bike and just transfer the zumo in and out of the mounts.
Dennis
Old Feb 5, 2009 | 11:38 AM
HDRider2002's Avatar
HDRider2002
Originally Posted by outofcontrolj
Ron_H; I actually started out on the ZUMO and did not find too many "load and go" routes out there. It was odd. I figured some of the Harley HOG groups would post those.
cfmii11 - I have both turned up to 100% and still nothing at 70 but at 45 it is clear as a bell. I am sure it is just wind but I thought I would ask. I have the full windshield too to help reduce the noise. If I put a CD in at 70 it is as clear as a bell and loud too just not the zumo....
There is also a "master volume" that my guess is you have turned down. Use the hard button at the bottom, that will bring the volume control on the screen, then you can use the second hard button to raise the master volume level. I have found that with the master volume all the way up, i'm often having to lower the MP3 output level on the volume screen to avoid distortion.
Old Feb 5, 2009 | 12:50 PM
monstead's Avatar
monstead
From: Dallas, TX & Santa Fe, NM when I can find the time....
You might also check out "Harley Ride Planner". http://rideplanner.harley-davidson.com/ There are thousands of "Rider Submitted Routes" and also "Great Roads". You will need to sign up to login to be able to create your own or pick an already submitted route. To keep it, share it or download it, you will need to save it to your profile. After it's saved, you click on GPS Syncronization to download it to your Zumo. I've been using this site a lot lately and am very happy with it.
Well I broke down and purchase a unit then took a trip from Cleveland OH to New York up through the Allegheny mountains and it was great.
The unit is completely detachable and plugs into the cigarette lighter and the AUX port on the radio.
The Zumo worked great on the trip. I loaded 2GB of music on it. The music was good to listen to as long as you are not going 70 since it was impossible to hear even with the radio turned up all the way. Anyone solve that problem?
Also is there a site that allows POI sharing?? It is going to be a nice weekend in OH and thought I would load a POI from someone that had a great route? Any thoughts?
Thanks for your help
Old Feb 5, 2009 | 09:22 PM
Berndude's Avatar
Berndude
Great info, Im looking at the fairing mount as I am not thrilled about handlebar clutter
