unbelievable vibration in fairing
#93
These problems sound so farmiliar. This vibration drives me nuts. I spoke with Gary Stroud who is a well know indy in the area and he told me he is seeing a lot of 96 TC's with excessive runout on the pinion shaft. I will check my fairing brackets. I noticed that my horn and air cleaner vibrate alot at highwat speeds.
#94
HD has upgraded the horizontal brackets and I think the large verticals as well. I did a write-up on adding strength to the vertical brackets and after 18 months and one accident they are still solid. When I had an accident in Oct. 2009 I asked the tech about changing the verticals, which are the ones I modified, and he said my fix looked like a permanent solution, so we didn't replace them.
#95
I'll bet you haven't seen this one. My wife complained of the exact same problem on her 2007 Ultra. A few test rides showed that the problem had nothing to do with the fairing, its mounting, or anything to do with non-engine related parts or issues. I changed the spark plugs and the problem dissappeared and stayed gone. The plugs had about 25,000 miles on them and the recommended change interval is 20,000 miles.
#96
I' ve tryed different plugs, gaps etc. nothing. all of my brackets have been reinforced. changed my front mount. all with no change. still vibrates at 1500 - 2000 rpm, at any speed or stoped. smooth everywhere else. never did change the the torque on the front mount. still gotta try that. would like to find a good mech to allign the engine. one thing I thought might be the culprit in my case. I have 21g cams and true duels. maybe the combo is just enough to affect the harmonics in that rpm range. it's a thought.
#97
#99
internet troll
06-09-2019 09:33 PM
