The paint is peeling on my master cylinder cover on my 07 RKC whats up with that any body know I think it should be covered under waranty but has anybody seen this
I had the same problem. Your brake fluid is leaking through the gasket under the cover. Check to see if the cover is tight if it is then remove it and check the gasket for cracks. Don't think this is covered under warrenty as lots of things shake loose on bikes and need to be checked and retightened.,
Hope this helps.
My 06 did the same thing. Its covered under Warranty. They gave me the std lid credit towards a chrome lid. Its been fine ever since - about a season and half of riding.
