Winter mods done
Old Mar 8, 2009 | 04:29 PM
flyingace's Avatar
flyingace
I LIKE that!
Good work!
Mind if I steal it?
Old Mar 8, 2009 | 05:38 PM
rjmac53's Avatar
rjmac53
very, very nice...
Old Mar 8, 2009 | 05:58 PM
georgemcghee's Avatar
georgemcghee
looks great. were the saddlebag lights plug and go or was there more to it. i see more $$$$ leaving my pocket.
Old Mar 8, 2009 | 06:05 PM
Bigmeanie's Avatar
Bigmeanie
Thanks guys, I would do the side panel lights again if someone wanted them, but it takes time and it's about $175.00 in parts and about 6 hrs to get them right. I don't know about the licencse plate (Showing it)?? However the plate cover is kuryakan curved cover. I had to be heat and form it to the fender, the lights in it are LED bolt lights. The bag lights are plug and go very easy to put on, comes with everything you need even a plug and play wiring harness. You can seal any of my ideas thats why there here. LOL
Old Mar 8, 2009 | 06:23 PM
gliderman's Avatar
gliderman
How did you replace the stock triple row lights on the lower fender? Is it just a matter of replacing them with the some led's? Any further info you can give on this procedure? Thanks......
Old Mar 8, 2009 | 07:38 PM
youngrider's Avatar
youngrider
Very creative..Looks really good!
Old Mar 8, 2009 | 07:47 PM
Xcrossbow's Avatar
Xcrossbow
That is a nice looking a$$.
Old Mar 8, 2009 | 09:16 PM
Bigmeanie's Avatar
Bigmeanie
The bottom light is replaced with 3 rows of 30 LEDs = 90 LEDs, the stock board from harley is only 5 LEDs (just Glows). I took the light out and heated it to loosen up the sealer they used. Once it is apart pull the stock board out and cut a piece of plastic to fit inside the light housing.(make sure it is big enough to to cover the three slots). Next I put it aganst the stock lens and mark the three light slots so that the mark is on the plastic and curves with the shape of the openings. I used three of the flexible LED strips from www.customdynamics.com/flex_led_array.htm (Item:4001-13). I stuck the LED strips to the marks I made on the plastic,(they are self sticking and flexable) then placed the whole plastic piece against the inside lens lining up the LED strips to the slots on the lens and apoxyed them in place, used RTV Black to seal up the light housing and mounted it back in place. Used the stock wiring for the running light and brake light set and thats pretty much it. It works great and it's super bright.
It is easier then it sounds and it works great. I looked at the running/break light Harley sells and it was just not bright enough for me, so I made mine own.
Hope this helps, any other questions just ask.
Thanks
Old Mar 17, 2009 | 06:49 PM
ncbeast's Avatar
ncbeast
So where did you get the lights for the holes in the fillers?
Old Mar 17, 2009 | 07:09 PM
Jerry L's Avatar
Jerry L
Man, that looks good! You are talented. Some great ideas there. Very nice!
Jerry
