Wild 1 Chubby 508 or 518 on Road King? Pros-Cons? Need Cables? Comfort?
Old 03-08-2009, 03:01 PM
ROGERinSEMO's Avatar
ROGERinSEMO
ROGERinSEMO is offline
Default Wild 1 Chubby 508 or 518 on Road King? Pros-Cons? Need Cables? Comfort?
Thinking of switching to Wild 1 Chubby 508 or 518 on my 2005 FLHRCI RoadKing Classic. I'm 6 foot 215 lbs. 34 inch inseam and 33 inch sleeve length. I'm looking for bars that will bring the controls closer to my body and keep my hands lower and keep me from leaning forward all the time. If you have made this change, could you comment on comfort, cables, or anything else I should know. Are there other bars out there that will do the same thing as these? THANKS!!!!!!!
Old 03-08-2009, 03:05 PM
PEZ's Avatar
PEZ
PEZ is offline
hey there
Im 6'3 and was 220 when I had my RKC--BY FAR the nicest riding improvement for me was the 518's! I had to do a 2 over clutch cable and Im pretty sure the brake lines stayed stock length even though I did switch to braided
Hope this helps!--PEZ
Old 03-08-2009, 03:19 PM
skyking's Avatar
skyking
skyking is offline
I put the 518's on my 05 RKC. I'm 6'0" tall 34" inseam and 34" sleeve. The 518's fit me perfectly. You will need to change the clutch cable, throttle and idle cables to longer ones. Wild 1's website says you can use the stock brake line, but you have to adjust it to fit. I didn't like the look of that so I changed the brake line too. I think it was 4" longer on the clutch cable and 2" on everything else. Wild 1's website used to have all the info, I don't know if they still do, but call them, they are great to work with.
Old 03-08-2009, 07:09 PM
ROGERinSEMO
Great guys, THANKS!!! Keep the info coming!!!!!
Old 03-08-2009, 07:19 PM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
I'll agree with what they are saying except for the clutch cable. Mine (an 07) used the stock length clutch cable and +4 on the throttle/idle, and brake lines. They say you can use the stock ones, but by the look of the pictures I decided I didn't want all the lines stretched that tight.
Give the guys at Wild 1 a call and they can pretty much tell you how they feel different compared to the others.
Old 03-08-2009, 07:30 PM
BIG Y 2014's Avatar
BIG Y 2014
BIG Y 2014 is offline
Default chubby 518s
same cable sizes as the others are saying here a pic of them
Attached Thumbnails Wild 1 Chubby 508 or 518 on Road King?  Pros-Cons?  Need Cables?  Comfort?-100_0798.jpg   Wild 1 Chubby 508 or 518 on Road King?  Pros-Cons?  Need Cables?  Comfort?-100_0795.jpg   Wild 1 Chubby 508 or 518 on Road King?  Pros-Cons?  Need Cables?  Comfort?-100_0797.jpg
Old 03-09-2009, 08:00 AM
ROGERinSEMO
Thanks Guys!! Any More???
Old 03-09-2009, 08:26 AM
Pastor John's Avatar
Pastor John
Pastor John is offline
These are the 508's on my '07 Road King. I "tolerated" them, but never really liked the 4" additional pullback and especially the "wheelbarrow" feeling of the grip angle. Folks say that the 518's are better in that regard. We used the stock length clutch cable and +2" throttle and brake lines. I think a better choice for the throttle and brake lines would have been +4" and tie them to the handlebars with the billet clamps that Wild 1 sells.
Old 03-09-2009, 03:08 PM
Buzzsaw's Avatar
Buzzsaw
Buzzsaw is offline
I had the 508's and loved them, however I am 5'7" and when someone taller road it the bars were too far back and not easy for them to use. I would see if you can find someone with them in stock and hold them both and over your bike and see which feel the best for you. Wildone makes a great bar and they look great.
Old 03-09-2009, 03:35 PM
mgrimmace's Avatar
mgrimmace
mgrimmace is offline
6th Gear
you might want to check out www.helibars.com pricey but well worth it
Quick Reply: Wild 1 Chubby 508 or 518 on Road King? Pros-Cons? Need Cables? Comfort?
