Wet radio problem
Yes you can get the fairing wet but it's like a water resistant watch take a shower with it on and works fine go scuba diving with it on (under pressure)and it fills up with water.Up until last spring I had always Armour Alled all the plastic and rubber parts but a guy on this forum who seemed to really know detailing a bike and the products used swore by this 303 Aerospace Protectant. I'm not a dealer but after trying it I pitched the Armour All.The 303 protectant was developed by the aviation industry and offers a real good uv protection and you can buy it at an Auto Zone.
Go figure, they wanted over $8 to ship a 16oz spray bottle and $10 to ship a gallon....
I never spray water directly onto the inner fairing. When I wash my bike, water is indirectly sprayed onto the inner fairing. I simply blow it dry with a Cycle Dryer. Then I take a damp cloth and do a detail wipe down. It looks good as new.
Radios & washings
No bike should be washed excessively (as most HD owners do) and you should never wash with a pressure washer! So... I was doing my weekly washing of my Sportster with a pressure washer last month and it would not start after; I left the keys in the ignition and it acted like a spigot and wetted the contacts! Took a while to blow dry (ever lip an ignition switch?) to start. Water can get everywhere (swithches, unprotected/worn connections, etc) even with a hose so best to wash "judiciously" and stay away from the instrument side of the fairing: you don't rinse of the dash in your car, do you? They are water-resistant, not water-proof. Probably got in a switch somewhere but here's a few self-diagnostics for the radio:
RADIO DIAGNOSTICS
To enter the radio diagnostic mode, press any two (2) station preset buttons simultaneously while turning ignition on. There are five (5) diagnostic modes (D1-D5) plus Automatic Volume Control (AVC) setting. Digits will change from 0 to 1 when function button is operated. If digit does not change, there is either a short or open on that circuit (see Service Manual or ED for codes). To cycle through the various diagnostics, use the LO/DX button.
D1: Switch Function Mode will display a five (5) digit binary code at the top of the LCD.
Digit 1=Mode Set, up & down
Digit 2=FPTT, RPTT, Volume up & down
Digit 3=Audio in, Squelch-, Eject
Digit 4=Audio-, Squelch+
Digit5=Audio+
D2: LCD displays an 8-digit code
Digit 1=PTT microphone Digit 2=Vehicle speed Digit 3=VOX break Digit 4=CB SQ break Digit 5=IC on/off Digit 6=CB on/off Digit 7=SPKR SW B Digit 8=SPKR SW A
D3: LCD Illumination function= display all items in LCD.
D4: Model year=Select model year as prompted.
D5: Software=Displays software information
AVC: Automatic Volume Control=Adjusts volume to engine speed. 0 to 4 range with 2 the factory setting and 4 being the most aggressive setting.
RADIO DIAGNOSTICS
Digit5=Audio+
