Here's a simple question...........
Old Sep 6, 2009 | 07:20 PM
maineultraclassic's Avatar
maineultraclassic
Default Here's a simple question...........
I put a new horn cover on my friend's horn, just a simple cover swap.
Before the swap the horn worked and sounded fine.
After the swap, the horn sounds weak and sick.
Does the tightness of the mounting nut have anything to do with the sound?
I swapped the wires thinking that was causing it, but it didn't change at all.
But, if he squeezes the horn to the cover at an angle.........the horn sounds normal again. As soon as he lets go, it sounds dead again.
Any ideas??
Steve
Old Sep 6, 2009 | 07:22 PM
HDUltraRider's Avatar
HDUltraRider
What cover did you use, I would put back the old one if it sound normal again then it has to be the way the cover is sitting that it is muffling the sound.
Old Sep 6, 2009 | 07:33 PM
mtnbikerx's Avatar
mtnbikerx
Is the horn contacting the cover in any way? Sound is simply transmission of vibration and maybe the cover is surpressing the horn's isolation? OR maybe a "bad ground" (when in doubt blame the ground)
Old Sep 6, 2009 | 08:12 PM
armyof1's Avatar
armyof1
somehow the cover is surpressing the horn. ive had it happen many times on different bike horn cover combos!
Old Sep 6, 2009 | 08:14 PM
pastorralph's Avatar
pastorralph
From: Creektown aka Lower Alabama, but not that low
I had mine do the same thing, I took the cover off, pulled the wires off and then reconnected them, and put the cover back on; horn worked fine. I think it was a connection issue. Just redo what you did and see if that works.
Old Sep 6, 2009 | 08:49 PM
maineultraclassic
The cover is the air-wing cover. I removed it from my bike this week, and installed it on his bike today. It's not blocking the horn at all, and it's not making contact at all, even swapping the wires didn't work.
Not sure what it could be, we'll take it apart this week and see what we can find. Of course now after hearing my Mini-Beast he wants one of those now.
Steve
Old Sep 6, 2009 | 09:04 PM
akodust's Avatar
akodust
Same thing happen to me two times. I ended up taking the bike in to stealer. They replaced the horn, it was still under wananty.
Steve
Old Sep 6, 2009 | 09:44 PM
Wally's Avatar
Wally
I'm in the middle of one of these situations right now.
Old Sep 6, 2009 | 10:09 PM
iclick's Avatar
iclick
I think this is the most likely suspect.
Old Sep 7, 2009 | 06:22 AM
Heathen's Avatar
Heathen
Try to loosen up were the horn mounts to the cover, I had the same problem and after backing off bolts all was fine.
