spectro oil for primary????
Old 10-31-2009, 06:38 PM
7125's Avatar
7125
7125 is offline
Thumbs up spectro oil for primary????
hi spectro oil for primary not synthetic ???? or iam i missing something
also looking for best place to buy
thanks gabe
Old 10-31-2009, 06:43 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I used Spectro chain case lube a couple times.As far as I know its not syn.When I went to buy it again the price was jacked up to almost 9 bucks a qt.!
Since then I have been using Valvoline 20wt50 motorcycle oil at 4 bucks aqt.
Cant tell any difference.
Old 10-31-2009, 06:45 PM
soos's Avatar
soos
soos is offline
Any synthetic in the primary is just a waste of money. All that is needed is a good 10w-40 dino oil such as Castrol GTX. The oil is not for lubrication but rather for cooling purposes. Can't tell you where to find Spectro. Sorry.
Old 10-31-2009, 06:48 PM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
thanks gabe
I've used Spectro with good results but it can be difficult to find.
Any good oil without moly seems to work well as does ATF.
Hope that helps!
Old 10-31-2009, 06:51 PM
1flhtk4me's Avatar
1flhtk4me
The chain and sprockets need to be lubed dont they?
Old 10-31-2009, 06:55 PM
7125's Avatar
7125
7125 is offline
ok thanks guy s but i a cvo there is a sticker that the customer has to remove from the primery and says you have to use synthetic why if it is just for cooling????
thanks gabe
Old 10-31-2009, 07:03 PM
dawg's Avatar
dawg
dawg is offline
Received 2,985 Likes on 1,726 Posts
Just slap some Dexron III in there.
Old 10-31-2009, 07:16 PM
zyepod's Avatar
zyepod
zyepod is offline
thanks gabe
Not saying it's the best place to buy from but I've bought it from Hog Wild Custom Motorcycles in Albany Ga.
Old 11-01-2009, 12:06 AM
BlackFLHR's Avatar
BlackFLHR
BlackFLHR is offline
Just changed my primary fluid this past week using Spectro Primary Chaincase Lubricant. Prior to that I had Redline MTL in there. Seems to work/shift just as well, and it was a little cheaper than the MTL. I believe you're correct; the Specto is not synthetic.
Old 11-01-2009, 12:24 AM
medic1555's Avatar
medic1555
medic1555 is offline
Anyone here ever use Bardahl lubricant? I see Dennis Kirk has it on clearance for $1.50/qt. Link: http://www.denniskirk.com/jsp/produc...afCatId=&mmyId=
Quick Reply: spectro oil for primary????
