Di Really need to replace the inner cam bearings?
Old 11-07-2009, 03:56 PM
HD REBEL's Avatar
HD REBEL
HD REBEL is offline
Default Di Really need to replace the inner cam bearings?
I plan on installing SE 255 cams into my 09 street glide with 4k miles. Do I really need to replace the inner cam bearings during the install? The tool cost for a one time use is a little high. Has anyone not replaced them?The miles are low and they are already roller bearings, is it really necessary? If so, does anyone want to rent me thier tools?
Old 11-07-2009, 04:24 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,944 Likes on 1,928 Posts
Put the Torrington's in. B 168's. You can get them at George's garage for $20 each. It's worth it if you are already in there. You can get a bearing puller from Auto Zone for free. http://www.georges-garage.com/tc_engine_2.htm
Last thing on the page.
__________________
Old 11-07-2009, 04:33 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
The cost of replacing the inferior INA's and the parts they take out is even higher!
Old 11-07-2009, 06:28 PM
davessworks's Avatar
davessworks
davessworks is offline
$20 each seems high. Check your local dealership. Mine uses Torringtons too! I got them for $9.95 ea (and then a further 30% off but that was a special deal).
Old 11-07-2009, 06:40 PM
stro1965's Avatar
stro1965
stro1965 is offline
+1 on the Torringtons!
Old 11-07-2009, 07:17 PM
HD REBEL's Avatar
HD REBEL
HD REBEL is offline
OK, Going to install them, cheap insurance! Found a set for $20. Thanks
Old 11-07-2009, 07:23 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
The cam bearing puller is $83 bucks on Ebay.
George's Garage brand.
You could buy it then resell it.
Old 11-07-2009, 07:32 PM
duffey11's Avatar
duffey11
duffey11 is offline
No need to replace. The bearings in the older models did have a recall may years ago. There is no need to change the bearing. The OEM bearing are of good quality and will last as long as any other bearing in your engine. If your being told that they are week, then why not replace the crank and rod bearing also? Just my opinion. Good insurance would to be buy the extended warranty.
Old 11-07-2009, 08:43 PM
Stansuski's Avatar
Stansuski
Stansuski is offline
Not changing mine,I am starting next week on my cam change in anticipation of my Fuelmoto pipe.I do not believe the sky is falling.
Stan
Old 11-07-2009, 09:03 PM
boom23's Avatar
boom23
boom23 is offline
The bearings are $7 something in amazon.com.
Quick Reply: Di Really need to replace the inner cam bearings?
