tubeless or tube type ?????
hi folks, i just bought my first harley,2009 road king classic, back in august. this is my first bike with wire wheels and i 'm wondering if they are tubeless or not. my front tire is a d408f and on the side, from what i can make out, it says that it can be used with or without tubes. i have seen tubeless wire wheels in the past.
Road King classic factory rims require a tube.
The Wide White wall tires are stamped tubeless but they do have a tube when used with stock spoke rims.
On my bike I carry an inexpensive 12 volt pump and also carrying SLIME,I have used the pump multiple times to rescue others and one time to rescue myself in the past 10-11 years. The pump offers unlimited air..you can air up multiple times and are also able to test/rotate tire to locate leak or move bike away from road while you figure out the problem..although they pump is very slow.(about 5 minutes for a dead tire)
I also carry some cheap plugs for tubeless riders..rescued several of those riders also.
I carrying the same set-up in our cars to help fellow motorcyclist..
Sitting on the side of a busy road or worse stuck out in a more rural area waiting 1 to 2 hours for a tow truck would be a negative and easily ruin your entire day.
i did this with a cheap pump for the motorcycle..and have used it many,many times..for a motorcycle you do not need an on/off switch..distance from tire to power is very short....slime also makes a very small pump although i have not tried it.
http://www.webbikeworld.com/Motorcyc...cles/air-pump/
Like others, I carry a small 12 volt air compressor. Have used it twice in the past three years and never on my bikes.
I do however always run the Dunlop D402 Police Tire version. If the tire does develop a flat, the sidewalls are stiff enough to hold up. You may can't go fast, but at least the bike is still rideable to a shop. Not quiet like a true runflat, but at least they work very well for what they were designed for.
