Oil filter change out
Old 11-22-2009, 05:16 PM
Jinks's Avatar
Jinks
Jinks is offline
Tinfoil.............
Old 11-22-2009, 05:36 PM
FLoTR's Avatar
FLoTR
FLoTR is offline
I use the aluminum foil too. Worked great on my 03 because it went a little past the underneath of the mount location but they have changed the oil filter mount since then because I have a large flat wall that's even with the filter and my foil just has to bump up against it. Still makes a mess. But you wanted to know what the dealers use.......they use the detail guys.
Old 11-22-2009, 06:53 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
I just did mine today. Made a trough out of the plastic cat litter jug. Worked great! Similar to the soda bottle trick, but I don't drink soda, so I used what I had.
Old 11-22-2009, 07:14 PM
dawg's Avatar
dawg
dawg is offline
Received 2,978 Likes on 1,724 Posts
Good thing you drink cat litter then, huh?
Old 11-22-2009, 07:19 PM
soos's Avatar
soos
soos is offline
Gotta be a west coast thing. Those guys have way to much fun...
Old 11-22-2009, 07:23 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Originally Posted by Captain Itch
I let mine leak out where ever it likes all over the frame and motor.When I am done I turn on the garden hose and spray it off..This method works real well for me..
+1 on this method!
Old 11-22-2009, 07:32 PM
16X9 Shooter's Avatar
16X9 Shooter
16X9 Shooter is offline
Have Billet Cool that replaces part that oil filter threads into.
Probably does not do much to help with cooling - unknown - never did test.
But, moves oil filter to where can get to easy. Still use some catch device..very easy..no spills or drips.
billetcool.com
Old 11-22-2009, 07:47 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
+1...
Old 11-22-2009, 08:10 PM
SeniorChief56's Avatar
SeniorChief56
SeniorChief56 is offline
Received 16,549 Likes on 4,760 Posts
thanks for the soda bottle tip.will try it when it's time.....for those that mentioned form fit tin foil, cardboard etc.those do not work on the 09's. plus I remove the toe shifter to make it easier
Old 11-22-2009, 08:17 PM
atrain68's Avatar
atrain68
atrain68 is offline
Shop towels and degreaser after I'm done making a mess.
Quick Reply: Oil filter change out
