Does it matter when you add stage 1?
Recently purchased my dream bike, a 09 black denim FLHT. Only has 3 miles on it as I cannot ride in Michigan winter. Anyways, I know that I am adding V&H Widow slip-ons before spring but was wondering if I can/could do the air cleaner and power commander at the same time, or wait until I get some miles on it. Personally I would think that it would be good for the bike to have more air running through it with the air cleaner and the extra fuel from the PCV to make it run cooler, but I don't want to mess anything up. I was going to purchase the PC-V through Jamie at Fuel Moto so the bike won't be on a dyno.
Thanks for the help.
I would do the air cleaner and the fuel controller at the same time as the exhaust system... Jamie can set the fuel controller based on what you have as far as equipment, with a stage 1, it is simple, when you add cams and etc. it is a little more difficult to get fuel management set up........
You won't mess it up. All you are doing is putting more air through the motor and richening up the fuel circuit to match the increase air. The bike runs better/stronger and much cooler. When I added a PCV to mine it dropped the oil temperature 20 degrees. Not important now but it will be in the summer.
There are alternatives to the PC-V that you could add before any modifications...the TTS comes to mind and you won't be tied to a generic canned map (which will still benefit greatly from a few runs on the dyno).
You've got some time so I'd suggest do some more research and reading...hate to see your dream bike turn into a nightmare.
Good luck!
