Vibration
Old 01-25-2010, 08:35 PM
ptl203's Avatar
ptl203
ptl203 is offline
I will get used to it...I will just have to make sure not to get stuck at many lights
Old 01-25-2010, 08:49 PM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
It vibrates even more when you are holding the front brakes at idle.
Old 01-25-2010, 09:16 PM
2DEUCE2's Avatar
2DEUCE2
2DEUCE2 is offline
The touring models engines are rubber mounted and aren't balanced while the Softail models are hard mounted but their engines are balanced which takes care of the vibrations at idle. So it is totally normal.
Old 01-25-2010, 09:23 PM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
My 10 RoadGlide is pretty smooth compared to my 07 RoadKing, that thing shook like a bastard at idle.
Old 01-25-2010, 10:15 PM
davessworks's Avatar
davessworks
davessworks is offline
Should have ridden a Softail Evo . . . Frankly I have no problem with either my TC Fatboy or my Ultra.
Old 01-25-2010, 10:22 PM
patriotmc's Avatar
patriotmc
patriotmc is offline
Have you looked at a tourer's engine at idle... sucker just hops like it's going to jump right out of the bike! Put cams in mine and got even more -- I love it!!
Old 01-25-2010, 11:34 PM
dohadex's Avatar
dohadex
dohadex is offline
Red face Pleasant Vibs...
I went from a 1998 fatboy to my 2010 Road King...and noticed the same thing regarding vibration.
The Fatboy was more of a "buzzing" vs. the RK which has a lower "frequency" and just isn't that obtrusive. It's the same but "different".
Folks tell me it will settle out a little once broken in...the rubber mounts soften slightly, etc. This gives you enough time to forget about it and just enjoy the ride.
Dex
Old 01-26-2010, 01:12 AM
Jday53's Avatar
Jday53
Jday53 is offline
Put cams and a big bore then watch it you might just hop and jump side ways at the stop light LOL
Old 01-26-2010, 01:26 AM
doc_cj's Avatar
doc_cj
doc_cj is offline
I came over from a Heritage, so I have an idea of what you are experiencing.
It's kind of like jock rash. It irritates the hell out of you at first, but later you appreciate having something to do while at a stop light.
Old 01-26-2010, 04:17 AM
mslater741's Avatar
mslater741
mslater741 is offline
went from a heritage to a road glide....i put off moving up for a couple of years because of it. cant focus on the gauges or gps.you get use to it ...sure glad i made the switch.
Quick Reply: Vibration
