HD Shock Pump / Zero Air Loss
  #31
Old 04-08-2011, 02:11 PM
mllgator's Avatar
mllgator
mllgator is offline
Before you take it back, try this; pump it up to just shy of your desired pressure, bleed it down a few pounds, and then bring it up to pressure.
If that doesn't work, take it back.
  #32
Old 04-08-2011, 02:21 PM
gambler's Avatar
gambler
gambler is offline
I have had this one for years, and I hardly lose any air on disconnect.
http://www.bkrider.com/bkrider/SKUSe...eria=C01170043
  #33
Old 04-22-2012, 07:08 AM
BowaHolic's Avatar
BowaHolic
BowaHolic is offline
mine came without instructions...so the little button is a bleeder?
  #34
Old 04-22-2012, 07:57 AM
Harley Hound57's Avatar
Harley Hound57
Harley Hound57 is offline
Yes sir it is.
  #35
Old 05-30-2012, 08:52 AM
spongetail's Avatar
spongetail
spongetail is offline
Sorry to keep ressurrecting this thread, but I pump my shocks on my 2007 FLHX up to about 10psi (per the manual since I'm a fatty). The gauge sticks at 10 as long as the hose is connected. When I go to disconnect the hose the gauge goes to 0.
Is this a bad pump or does the gauge normally go to 0 when disconnecting?
  #36
Old 05-30-2012, 08:55 AM
kwo51's Avatar
kwo51
kwo51 is offline
08 shocks and earlier were better!!!!!!
  #37
Old 05-30-2012, 09:44 AM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
so how often does one check air in the rear shocks? Do these bleed off? Can you check with standard tire pressure gauge or does the HD pump have a gauge in it?
I do not have a pump as of yet, dealer checked shock pressure this Spring when i got it out of their Winter storage.
  #38
Old 05-30-2012, 10:11 AM
Stash905's Avatar
Stash905
Stash905 is offline
Originally Posted by brickmann
That's not what they mean by zero air loss-they mean you pump it up and leave it attached for a half hour to see if your shocks have a leak
Wrong.
  #39
Old 05-30-2012, 12:26 PM
skratch's Avatar
skratch
skratch is offline
Received 4,236 Likes on 2,473 Posts
when you disconnect the hose, you are no longer monitoring any air pressure. yes, this is normal.
  #40
Old 05-30-2012, 12:53 PM
zfdtruckman's Avatar
zfdtruckman
zfdtruckman is offline
I thought for 49 bucks it is very high quality, made much better than my son's little plastic pump for his high end bicycle and only 9 bucks more. I lose 0 psi when disconnecting. If I did lose anything, of course my dealer would replace it.
Quick Reply: HD Shock Pump / Zero Air Loss
