Can't get oil filter off
Old 03-03-2010, 08:23 PM
shagnasty's Avatar
shagnasty
shagnasty is offline
+1 on the K@N 171C.
Old 03-03-2010, 08:31 PM
piasspj's Avatar
piasspj
piasspj is offline
Messed with a few stuck filters in the past, tried teh screwdriver thing once it ripped the filter apart, what a mess. Had better luck with large Channel locks but if you start crushing the filter forget it (grabbing near the end closest to the seal works best).
Fortunately these were not on a Harley and had more room around them.
On the Harley I used a cap style wrench that I cut myself for the first change, it was a tight fit but worked, Since then I've used oil filter pliers. A strap wrench would work too, I have one that fits on a 3/8 ratchet.
Old 03-03-2010, 09:00 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Speaking of K&N, where could you get a case at a good discount?
Old 03-03-2010, 09:09 PM
tbob's Avatar
tbob
tbob is offline
I get mine at Autozone
Old 03-03-2010, 09:17 PM
acchd's Avatar
acchd
acchd is offline
I've always used a strap wrench on my Harleys. If it starts to slip I just place some heavy grit sandpaper between the filter and wrench band and it works like charm.
Old 03-03-2010, 10:03 PM
RKKY's Avatar
RKKY
RKKY is offline
Usually am able to get them off with one similiar to TheBagger's, just a little more heavy duty. Usually have to use it 3-4 times a day when working and the the H-D one wears out too fast. For the filters that are really stuck on I use a Snap-On strap wrench that hasn't failed me yet.
Old 03-03-2010, 10:11 PM
bwana1's Avatar
bwana1
bwana1 is offline
Truely amazing. Fourteen replys and only one person caught on that the "crank sensor" is in his way.
Remove the crank sensor and the cap wrench fits on no problemo.
Bwana
Old 03-03-2010, 10:51 PM
cap5369's Avatar
cap5369
cap5369 is offline
Originally Posted by shagnasty
+1 on the K@N 171C.
Yup never have to worry about that again. Before the K&N I had to go old school and poke a hole in it with the trusty screwdriver to get it off.
Old 03-04-2010, 12:36 AM
heywood727's Avatar
heywood727
heywood727 is offline
Another Vote for the K&N.
Old 03-04-2010, 07:18 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Originally Posted by The Shute
Happens to me occasionally, I use either a large pair of channel locks
I had to use those once!
Quick Reply: Can't get oil filter off
