cams help asap!
I bought some se203 and just tore the bike down. The bike was used when I bought it. Tore it down and found out it already has se203 in it. What cams would help my 88cu, pc3, and 2-1? Se211 or se255?
unless you bump the compression and are set on SE, 203's or 204's are the best you are going to get with stock 88. 255's are for 96". If you want to switch to another brand go with andrews 21's in a stock 88.
So, I have had the wrong maps in my bike from FuelMoto since I had no idea about the cams. So the 211's or 255 are to big? I really dont want to spend a bunch of money on this. I already have all other parts, just need thoughts and help on cams.
If it was me I would do one of two things.
1. See if your dealer will trade the 203's for some 204's. It is really a waste of time and money going anymore aggresive than that with a stock TC88. Even with these cams you cant get the full benefit from them without some headwork.
2. Button her back up and have Jamie send you a map for the 203's. You will be pleasantly surprised considering it is not getting enough fuel for that cam configuration.
Just my $.02
Just my $.02
