Rear Wheel Clicking / Tapping noise
Old Apr 24, 2010 | 07:23 PM
shortride's Avatar
shortride
Originally Posted by TickTock
Well bad bearing was at 19600.
However, the clicking noise that I started this thread with still exists. The bearings were replaced by a different dealership since I ended up having to be towed in. So now I have a new IDS bearing and two new bearings in the wheel. When I spin the wheel the noise sounds as if it is coming from inside the IDS unit.
When I had the IDS bearing replaced the tech said he checked the rubber inside the of it and they did not look worn. I am at a loss to what could be causing this issue...
Here's what I think it may be. This happen on my '09 Ultra Classic. Somehow, someone has got the fuel tank hard plastic vent tub out of position. On mine, it was rubbing against the inside of the drive belt notches only when pushing the scooter in reverse. Yours could be doing the samething in either direction.
Remove the seat and find the fuel tank vent line that comes out below the left rear side of the fuel tank. Trace where it goes and pull up on it and see if that takes away the ckicking sound.
Old Apr 24, 2010 | 07:51 PM
Scorpion07's Avatar
Scorpion07
I have a piece of casting slag in my hub, and it's too big to fit through the small slots in the spokes. It doesn't make noise now, since I think centrifugal force has lodged it somewhere in the wheel. It's not causing any problems other then the noise every now and then.
Also I think I can remove it once I remove the wheel bearings and the long spacer beteen them.
I had to take the wheel off to see it floating around in there. I noticed it before I put on my IDS.
Might be something to look at?
Old Apr 24, 2010 | 08:18 PM
dirtracin23's Avatar
dirtracin23
Along those same lines, my battery tender lead had been routed out the left side and was riding on the drive belt.
HogDoc, where you at? You need to chime in on this one.
Old Apr 24, 2010 | 10:04 PM
TickTock's Avatar
TickTock
Well the wheel has now been off three times. First time was the tire change and that was when the noise started. The second time the IDS bearing was replaced and the rubber isolators inspected. Today was the third time and both wheel bearings were replaced. I don't think it is a tube or wire rubbing because the sound appears to be coming from the IDS basket somewhere. Strange this is that the tech took it apart to replace the bearing a week ago. Could the rubber be expanding/contracting from the pressure when the wheel is turned? I guess I could explain the clicking sound now like when you turn a balloon in your hand with an echo (IDS basket???).
Old Apr 26, 2010 | 01:19 PM
TickTock's Avatar
TickTock
Is there room in the hub once the spacer and wheel bearings are installed for small debris to be rolling around?
Old Apr 26, 2010 | 04:43 PM
TickTock's Avatar
TickTock
ok, I guess I am talking to myself at this point, but I want a resolution here in the event some other sap needs help.
I took it to the dealer and they readjusted the belt. Looks like it was too tight. My guess is that the creaking noise was the rubber isolators squeezing against the walls of the bowl this time around.
So bad isolator bearing then bad wheel bearing and then belt too tight. Ahhh, the joy of Harley ownership. It's always a 2-3 tripper...
Old Apr 26, 2010 | 06:54 PM
Retrop's Avatar
Retrop
So, when you took the bike in, the dealership replaced the first thing they came to??? Instead of checking out the whole rear axle to see what else could be the problem, they jumped to conclusions.
Typical behavior for a young, inexperienced technician, mechanic or knuckle buster. The older, wiser mechanic would have pulled the whole thing apart and diagnosed the entire rear axle assembly before he started R&R parts. Inexperienced mechanics add a lot to the cost of maintenance.
Old Apr 26, 2010 | 07:25 PM
trib's Avatar
trib
Gentlemen,
Just a thought. I had the (seemingly) exact same experiance. After replacing my wheels, (from mags to spokes) while backing my '98 RK out of my garage, I first heard the "clicking". Slowly, I took her out on the road, and the clicking could still be heard. I nursed her home then trailered her to my dealership where they (said) they checked the bearings, re-tourqed the axle bolt, checked the wheels, checked everything and found nothing. I paid the bill and off I went. I got about 20 miles and while negotiating a turn, the tranny went out to lunch and never came back. I'm not saying the clicking had anything to do with it, but......
I'm now on an '04 RK Classic.
Old Apr 26, 2010 | 08:39 PM
Scorpion07's Avatar
Scorpion07
Yes there is. Even with the reinforcement ribs inside the hub. In fact it was bouncing between inner spacer and the ribs untill it lodged somewhere.
Old Aug 9, 2010 | 06:10 PM
christopher.roden's Avatar
christopher.roden
Stage I
Was your problem resolved completely? I have the same problem that you described. I have an '07 Fatboy with only 3500 miles. I can't imagine it would be anything crazy. At least I hope it's not! It's at the dealer now and they will start work tomorrow. Other than testing driving before I bring it home, do you have any other suggestions?
