How I Checked Cam Chain Tensioners on TC88 03 RKC
Old Aug 10, 2016 | 12:16 PM
  #41
speeddaddy's Avatar
speeddaddy
2000 wide glide with 34k miles. Never under 75 mph.
Old Aug 10, 2016 | 08:46 PM
  #42
Campy Roadie's Avatar
Campy Roadie
That isn't one that will get you. It's the inner.
Old Oct 25, 2017 | 08:00 PM
  #43
JonnyBlaze's Avatar
JonnyBlaze
I know this old but I just bought an 03 Electra with 21k miles. Ive read up some on this issue and am concerned about it. What exactly should I do and get to fix this? I dont want to tear it apart just to inspect it. I want it fixed so I wont have to worry about it again. I need part numbers etc... Thanks!
Old Jan 1, 2018 | 01:48 PM
  #44
03_FatBoy's Avatar
03_FatBoy
I also found this informative, as I just bought an 03 ultra classic, with just under 44,000 miles on it. I bought it from the dealer, so I may see if I can get the previous owners info, and call him to ask about last inspection. The bike has adjustable push rods, so it is likely the cams have been out for one reason or another. Anyway, I know this is old, but wanted to post on it.
Old Apr 6, 2018 | 10:13 AM
  #45
JTM65's Avatar
JTM65
Default Cyco pads
I have an 01 RKC and I will be going in to check the pads as well. If they are worn I have some Cyco pads ready to go in. If they look okay then I will ride out the season and go with S&S 509 cams this winter. All about maximum ride time! I think on the subject of cause for the failure that shoe material manufacturing, spring tension and also chain condition, or did the links get properly deburred before the chain was constructed, all contribute.
UltraClassicElectraGlide
Jun 15, 2014 12:40 PM
EasyRider13
Oct 5, 2013 05:57 PM
ParkerH
Nov 3, 2011 04:27 PM
mrmud4x4
Aug 15, 2011 09:36 PM
Howard
Exhaust System Topics
27
Sep 29, 2006 10:38 PM
