Help With a Power Commander V with Auto Tune
No wonder....you need new AFR tables. Wow...who did that?
I can't post mine now, as I'm on my work computer, but if you click on the link to the other post above you will see ICLICK's tables. Just change your AFR values for his...except I wouldn't go any leaner in the cruise range than 14.4 unless you have an oil cooler. Depending on where you ride of course.
Save the new AFR values for both cylinders, clear the previous trims, save the map under a new file name and send it to the PCV.
Then go ride....AT should do the rest. If you get any pinging or knocking then I would first try lowering AFR values a bit in the range I suspected the ping occurred. Then I would adjust the timing + or - in 1 % increments until it went away. When you start playing with timing you should probably head to the dyno....but you say cash is a factor....so it will pay to have patience and play with it a bit.
Hope this works
Ok I changed to Iclick tables but I only went to 14.2 I will take it on long ride as soon as possible.
Thanks for all the help
I hope jammie reads this and puts his 2 cents in.
I will take all the help I can get.
O by the way I am in Southern Colorado
Whoever set-up your target AFR tables missed by 1000 RPM's. The 14.5 values should start at 2000, not 3000, and make sure they stay lean to 15% TP. The rule-of-thumb is to lean AFR's in the cruise-range (2000-3000rpms and 5-15% throttle-position), which will improve mileage as long as you keep your wrist out of the throttle. If you set them to 14.2 you shouldn't have a big problem with heat, and you could go higher if you have an oil cooler installed. A link to my write-up has already been posted. With or without a cooler consider the map-switch option described in my write-up.
I put in the new AFR tables
Well I put in Iclicks tables and road my bike to work and back about 65 miles round trip I only went up to 14.2 It seams to have made a big differance I will ride it for a couple more days. I will try to keep the wrist out of it and put a full tank so I will know how I am doing on the MPG
You were running 13.5:1 in the cruise range where you probably run most of the time, and that's way rich for mileage. It's good for cooling and that's where I have my rich base map set, but I wouldn't run it there all the time. Keep us posted, as that's probably going to do it for you. Experiment and find the sweet-spot for mileage and cooling for your taste.
Once you establish that mileage is better, you can taper your target AFR's in the 20-40% TP areas of the cruise range, but I would leave 60% and above alone. You want the performance when you twist the throttle, and you should be at 13.0 at 80-100% TP.
Add an oil cooler and you can run 14.6:1 except in heavy summer traffic. I took a ride today in 90° weather and at 50mph I was running 230-235° on the front head as long as I stayed moving, up to 245° or so when I got back into the stoplights, and saw only 200° max on oil temp. Those are good numbers IMO.
It's really a matter of preference. You can install a map switch for close to nothing and run two maps. One set up for cooling and another set up for fuel mileage. OR...you can run AT as described below and switch AT on and off with the switch so you can have the best of both worlds.
I agree with Tony. AT will not improve cooling if your PCV base map is correct to begin with. Do you buy your PCV from Fuel Moto? If so, you should be in good shape, but Tony's map-switch suggestion is a good one. That's one feature of the PCV that too few owners are taking advantage of, IMO.
