Adjusting a True Track and a review...
I picked up a true track on e-bay. I checked it out and the installation seems easy enough. The only question I have is on the adjustment of the rod ends. Seems to me that when the bike is up on the jack all I have to do is adjust the rod ends so they line up the threaded holes in the mounts apply a bit of lock-tite to the bolts and torque them in, that is that. I noticed when I did a google search that the maker says no adjustments are needed (on a new unit). Mine came apart in a box. Now I've done a wheel alignment and all is well there. Thought I should check before I put the thing on.. Oh, it's for my 05 RK Classic. I posted this on the Suspension section but there seems to be more interset here.
_____________________________
RE: Adjusting a True Track
Thanks. She's all lined up and the unit is on. I took it through an S curve on rte 95 near by. I used to have to back off to 65mph or so because the wooble bothered me.. I made 3 passes 65-70-75mph and that pain in the xxx wooble is gone... I' m going to have to put some miles on it to see how much the handling has changed but so far so good. If it wasn't for this forum I never would have found out about this thing. Good Stuff!!
