Temporary Zumo mount
Old Jun 3, 2010 | 01:31 PM
slime_dog's Avatar
slime_dog
Question Temporary Zumo mount
I will be renting a bike (ElectraGlide) soon. I would like to run my Garmin Zumo on it but don't want to transfer the handlebar mount. Has anybody tried the suction cup (auto mount) attached to the speedo or tach glass? I thought about trying that and plugging into the cigarette lighter for power. I realize that the Zumo "gas guage" will not work but that is the only function I see that I will loose.
I also thought about attaching it to the gas cover but I am not sure it will stick to a curved surface.
Any insight???
Old Jun 3, 2010 | 01:52 PM
monstead's Avatar
monstead
From: Dallas, TX & Santa Fe, NM when I can find the time....
Wouldn't try it because of the curves on the parts you speak of.
I rented a SG out in CA and took a U-Bolt RAM mount (I use a fixed mount on my bike so I had this one "in stock"). Also took the correct size wrench...it was small so not a big deal. Anyway, it was quick to install and WELL worth having in an unfamiliar area. I plugged into the cig lighter
Old Jun 3, 2010 | 02:03 PM
nevets61's Avatar
nevets61
Ran my Nuvi suction cupped to the tach glass on a 1000 mile round trip, never removed mount and it was suctioned on as tight as the day I put it on when I removed it. Should be fine as the tach glass if flat...
Old Jun 3, 2010 | 02:20 PM
jberg's Avatar
jberg
First of all, gas gauge is subjective. Only registers miles ridden (GPS tracked) against a mile limit you type in.
Second, suction cup might work but if it doesn't, you're screwed.
Bite the bullet and bring a "U" bolt type handlebar mount and a wrench and be sure.
Monstead had it right.
Old Jun 3, 2010 | 02:23 PM
todd-67's Avatar
todd-67
The suction cup mount in my truck for the Nuvi lets go every from the windshield once in a while no way would I use a suction cup mount for my expensive Zumo.... Just my opinion.
Old Jun 3, 2010 | 02:53 PM
vinnieee's Avatar
vinnieee
I purchased a U-bolt RAM mount set up from gpscity.com for about $11 - it's worth it and easy install/remove from rented bike.
Old Jun 3, 2010 | 06:01 PM
Airborne350G's Avatar
Airborne350G
That is the way I would do it also. I would not trust a suction cup to hold the GPS. I have had them fall of the windshield in the car enough...
NightHunter
Jan 29, 2016 01:18 PM
Londonbike
2014-2024 Touring Models
May 24, 2015 11:09 PM
Plow Jockey
Mar 13, 2015 01:38 PM
Dirtball
Jan 7, 2013 04:32 AM
aviscomi
Jan 20, 2010 08:03 PM
