16" ape hanger install
Old Jun 17, 2010 | 08:51 PM
JG09's Avatar
JG09
Default 16" ape hanger install
A buddy has a 2010 FLHRC and nees 16"apes cause he is 6'3". We are having problems finding the extended front brake lines. Do you have to replace the 3 lines or just the line from the master cylinder? Also, I heard you want to replace the bar bushings with poly ones? Any help is appreciated. Thanks.
Old Jun 17, 2010 | 09:48 PM
shagnasty's Avatar
shagnasty
I did from the master cylinder to the calipers on mine. I used Magnum Sterling Chromite II lines. they make a double line piece for the bottom end. Then you buy the top line in whatever length you want. I kept the stock bushings.
Old Jun 17, 2010 | 10:44 PM
Big Jake's Avatar
Big Jake
You have to replace them all. Reason is the line from the master cylinder to the spliter for the duals is a different fitting. You will need to get all 3 lines and a new spliter. Drag Specialties makes all the stuff for a lot less then HD.
Old Jun 18, 2010 | 12:46 AM
jrock387's Avatar
jrock387
i second the sterling chromite II lines, they look great. and yes you have to replace all of them.
Old Jun 18, 2010 | 12:09 PM
slick10's Avatar
slick10
You really do want to replace the stock riser bushings with poly (heavy duty).
Old Jun 18, 2010 | 12:35 PM
XMA's Avatar
XMA
+1 on the Magnum Sterling Chromlite II. Used them on my 09 Street Glide when I put 16" cyclesmith apes on. You need the lower dual disk kit and I need a 35" upper.
Old Jun 18, 2010 | 05:22 PM
5 Speed Suicide's Avatar
5 Speed Suicide
If you have ABS you should only have to run a new upper brake line.
Old Jun 19, 2010 | 12:17 AM
pittz5's Avatar
pittz5
+1...I didnt replace my lower lines.
SeaZund
Shovelhead
13
Dec 8, 2014 03:58 PM
Pngiaca
Feb 3, 2013 07:35 AM
JG09
Jun 18, 2010 12:02 AM
PlayManXXX
Wheels/Tires
Jul 16, 2009 10:03 AM
fkstk181
Aug 30, 2006 09:05 PM
