First tank of 89 octane!!
Hey there,
My wife and I went to Blowing Rock yesterday. Spent the night and came back today. Stopped at a Marathon station about 8 or 10 miles south of Stations Inn off the Parkway. All the 93 octane pumps were out, so we filled up with 89 octane. I didn't see the usual 10% ethanol stickers. Asked my wife to listen for pinging since I'm almost deaf and wear earplugs anyway. Stopped at Station's Inn for a late lunch and came on up the Parkway to Tuggle's Gap and headed up Route 8 to I-81. Got home and filled up......51.4 mpg............that freakin' ETHANOL is killin' us. My other two tanks were 93 octane Shell and BP and mileage was 42.3 and 42.5......and my Sweetie said she didn't hear any pinging. I may have to start searching out Marathons. They may have ethanol and just no pump stickers. Anyone know for sure?
Thanks,
bomtek44
Thanks,
bomtek44
Hey there,
Thanks,
bomtek44
Thanks,
bomtek44
East
Live on the East coast of VA, no choice but 10% ethanol here. From my last 6 years experience with my Harley it has not hurt anything. Reliable reports say a few % reduction in fuel mileage. You cannot go by seat of paints one tank full thing. I can very my bike 8 mpg by easy cruising, stiff head wind or enjoying the roar. The ethanol will absorb a little water and probably is helpful on those rare times that you may pick up a little water. My bike appears to run OK on mid grade but like most just put premium in it. There is not much difference in the btu (power) count of regular or premium. The additive to premium slows the burn rate down so it does not ping (explode) in the higher compression engines. Actually you will get less mpg with premium in a gas engine that does not require it.
Just my opinion
Boomtek44 Nice country up there were you live, have people up there
Just my opinion
Alcohol burns hotter, bad for air cooled engines. Racing engines using alcohol are jetted much riccher than gas engines. I `d never use 10% ethanol fuel in an airplane engine for fear of overheating or detonation. Won`t use it in a chainsaw either for same reasons. If you would jet accordingly than it would be viable. Example: flex fuel cars are programmed to use ethanol, fuel milage will drop accordingly due to richer mixrure.
A 1 tank fill up wont give you an accurate figure. There's no way you're gonna fill that tank to exactly the same level each time you fill up.. so you have to average it out over many fill ups.. the more fill ups in the average, the more accurate the figure.
