Help, clicking noise driving me crazy
I started getting a clicking noise r/r of my '07 SG. It happens after several miles and it doesn't matter if the bike is running or not. First thing I checked were the wheel bearing, removed wheel no problem with bearings. The noise is a ramdon click another words it is not a steady rhythm. Sprocket and bolts ok, rotor and bolts ok, brake caliper and pads ok. I also hear it when I jack it up after a ride, so it also happens with no weight on it. Please help any feed back is greatly appreciated and thanks in advanced.
Clicking
You state even when the bike is not running, are you saying standing still th bike makes the clicking noise? Or are you stating while rolling it, it makes the clicking noise?
After riding and sitting cooling down they all make the clicking noise as things cool down and the metal contracts.
Try jacking it up, and spin the wheel while sitting right next to it, motor off. If you can't identify the exact location have someone else try the same thing. Could be a loose weight, even if they're glued on, one might be somewhat loose. Otherwise I have no clue.
