Clicking noise when backing up
Old Jan 17, 2006 | 05:22 PM
06Softail's Avatar
06Softail
3rd Gear
Default Clicking noise when backing up
I'm getting a "clicking" sound/noise when backing the bike up when its not running...
any comments?
Old Jan 17, 2006 | 06:01 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Clicking noise when backing up
Take the baseball card out of your spokes. Just kidding, couldn't help myself. Have someone kneel down at the back of your bike while you back it up to see if they can identify the noise. It could be anything at this point.
Terry
Old Jan 17, 2006 | 06:21 PM
HDF Tech's Avatar
HDF Tech
Check the belt out for noises, especially if you just washed the bike.
Old Jan 17, 2006 | 07:32 PM
Wombat's Avatar
Wombat
Baseball cards in your bike spokes...now that takes me back a few years!! And we thought we were soooo cool!!!
Old Feb 3, 2006 | 07:18 PM
overdrive's Avatar
overdrive
My Roadstar Warrior has done this pretty much since it was new. Figured out it was the belt.22,000 miles later with no problems or excessive wear on the belt.
Old Feb 3, 2006 | 09:57 PM
Rodent's Avatar
Rodent
Wombat, most of us did put the baseball cards in the spokes, and yes, we were cool.
BUT............................................... ...........................
Do you realize what that card would be worth today?[sm=yikesomg.gif]
Old Feb 3, 2006 | 10:50 PM
Primo's Avatar
Primo
ORIGINAL: mickeymaxharley
Luckily I just used some of my dad's Mickey Mantle rookie cards whoever that was.
Old Mar 23, 2007 | 01:57 AM
bobby5's Avatar
bobby5
My new 07 dyna does this too. Is this anything major or should i not even worry about it? It only does it when im backing up
Old Mar 23, 2007 | 01:13 PM
wesd41's Avatar
wesd41
Its just the drive belt teeth against the pulley. Check that your rear wheel is properly aligned.
Old Mar 23, 2007 | 06:23 PM
glide's Avatar
glide
ORIGINAL: bobby5
You'll find that if you watch the belt as you roll the bike forward and then watch it as you roll it backward that the belt tracs to opposite sides of the pully which is a normal thing on harleys, nothing to worry about. They sometimes make a noise when backing it up. Just make sure your wheel alignment is spot on.
