Swing Test Spec. Help!!
Old Aug 10, 2010 | 10:49 PM
joechief's Avatar
joechief
Default Swing Test Spec. Help!!
Anybody got the specs. for the swing test or fall away test for an '06 Road King Custom?
Thanks in advance!!
Joechief
Old Aug 11, 2010 | 03:02 AM
Harleypingman's Avatar
Harleypingman
Do you mean the "swing test" in the HD Service Manual for testing the the steering neck?
Old Aug 11, 2010 | 07:22 AM
imrotton2's Avatar
imrotton2
swing ,swing,and start to swing
Old Aug 11, 2010 | 08:04 AM
joechief's Avatar
joechief
Yes. Joechief
Old Aug 11, 2010 | 10:45 AM
Harleypingman
Raise bike so that front and rear wheels are same distance from floor; remove accessories that may effect front wheel swing.
Turn front wheel fully left and release. Wheel should swing right, then left, then right (the last need only be a little and need not leave the wheel centered).
The SM has additional information for correcting swing.
Carl
Old Aug 11, 2010 | 03:19 PM
asm481's Avatar
asm481
Do you leave the clutch and throttle cables attached to do this test?
Old Aug 11, 2010 | 06:57 PM
harleytuner's Avatar
harleytuner
Unhook the clutch cable and if it is atteched to your forks remove the clamp. One way to tell if your neck is loose it to ride it to about 50 MPH then coast down to about 30 MPH or so with your hands just off the grips, if it's loose your bike will start to wobble, usually around 35 MPH or so.
hogowner69
2014-2024 Touring Models
May 29, 2014 08:12 AM
hojones
Welcome Area Only
17
Jan 15, 2010 05:53 PM
hd0wner
Mar 11, 2009 08:28 AM
rockhard69
Welcome Area Only
Aug 8, 2008 09:16 PM
