oil relief spring
Old Aug 28, 2010 | 02:01 PM
jobo3800's Avatar
jobo3800
6th Gear
Default oil relief spring
how do i replace the oil relief spring on my 2005 ultra tc88.has low oil pressure at warm idle and sure this is most likely the problem,harley replaced once under warranty but have bein told the stock spring isn't much and need to upgrade to a better spring.
Old Aug 28, 2010 | 05:50 PM
BadPiggy's Avatar
BadPiggy
Are you referring to the spring located in the bottom pickup port of the cam plate?
Old Aug 28, 2010 | 08:15 PM
jobo3800's Avatar
jobo3800
6th Gear
i assume so,
Old Aug 28, 2010 | 08:46 PM
BadPiggy's Avatar
BadPiggy
It's not just your Harley with low OP at warm idle.
They are all this way.
It's a low pressure lubricating system.
However, it can be increased.
A "roll pin" is what holds the spring in its little hole.
Either use a "roll pin punch" or something similar to push the roll pin out.
You don't have to totally remove it.
Careful while doing this as there's a couple other parts behind the spring.
DON'T replace with a new stock spring.
You'll get the same results.
Order yourself a Baisley spring.
http://www.baisley.com/oil_spring_product.htm
These really do work.
I run them in my bike and have installed in a few others.
Ask your buddies if they're interested in getting one, too.
Split the shipping with them.
Old Aug 28, 2010 | 08:51 PM
BadPiggy's Avatar
BadPiggy
The Baisley package will have complete directions included.
Old Aug 28, 2010 | 09:58 PM
jobo3800's Avatar
jobo3800
6th Gear
thanks for your help i was told baisley was the best.thanks again
NECaveman
Oct 29, 2012 09:25 PM
speakerfritz
Jun 17, 2012 01:13 PM
jobo3800
Exhaust System Topics
13
Mar 24, 2011 12:12 AM
jjb
Nov 7, 2006 08:57 PM
MAX EVO
Oct 10, 2006 05:30 PM
