needin more light
try these simple tricks...the first one leaves the passin lamps on when you switch to high beams...the second one lites up both high & low when you switch to high, low is only low....all this fine info courtesy of TXBOWHUNTER
http://www.*****************/forums/at...25770&d=112639
http://groups.msn.com/toddsharleypix/tow1.msnw
scroll down to headlight mod...
paul
paul
A set of aircraft landing lights will give you more light.
[IMG]local://upfiles/17633/CD080D3204014725AE7C10A64C1CDECA.jpg[/IMG]
[IMG]local://upfiles/17633/1E06E77300A34594A20A5B1CDE2A5E16.jpg[/IMG]
They are Wagner bulbs. You can get them at NAPA, Tractor Supply and I believe CarQuest for about 9 bucks. They come in a variety of wattages. Those are 35 watts, the same as the stock bulbs. They are unfluted, so they have a strong beam and so not disperse the light to the side.
I can't get the first link to open. Is there a different link to the site?
Thanks
Thanks
ORIGINAL: Ballz
Thanks
Thanks
I wouldn't reccomend replacing your 35w passing lamps for higher w... I've done it and it is a P in the A... the light cups heat so much inside that your bulb's filaments break with the slightest vibrations.
You are going to be replacing bulbs every Sunday. Install additional lamps instead.
Regards.
