string type vs mushroom tire repair
Time to get the bike ready for solo trips.
Last ride I was on, a buddy picked up a nail......one guy had a plug and another 3 co2's cartridges. They got him back on the road with a 1/2 inflated tire, but did make it to town.
Just read the searches on tire repair. Any one used both types........which is "best"?
Also 1st hand knowledge on which pump is the way to go.
I use Stop & Go Pocket Tire Plugger and Have a Slime Compressor for pumping the Tire back up and don't have to worry about trying to fill the tire later on few gas stations have air any more and if they do they either charge or it is out of order .. So far not needed it on mine but have put a couple riding buds back on the road with it .. Stop & Go is a Mushroom style Plug and does a fine job..The Slime Compressor takes little space and pumps the tires up great
I carry and have used the braided cord type plug,with the two tools to install the plugs,and i carry a Cycle Pump compressor,it is a quaility unit
http://www.bestrestproducts.com/c-13...bo-wgauge.aspx is what im carrying
+1 on the Stop & Go Tire plug. Easy to use on the side of the road. Used it once years ago with a buddy on a ride in SD, where we had the CO2 cartridges. Now I keep the kit (along with a pump) in my saddlebags for the same reason, the CO2 got the job done, but not really well.
I use an Airman Tour60 pump. Here is a review http://www.webbikeworld.com/r3/motor...irman-sparrow/ and you can get them for $25 on a number of web sites, http://www.sportchalet.com/product/302080_3042088.do
I have not used the pump on my bike for a flat, but, it's in the saddlebags 'just in case'
Jerry
BTW, the S&G comes in a real nice small zippered bag to keep all the stuff together in your saddlebag.
+3 on the Stop-n-Go and the Slime compressor, but read the directions carefully on the SnG. It's critical that you invert the mushroom plug in the insertion tool before plugging the tire because the plug will not pass through the hole otherwise. DAMHIK.
I have used both on the road and the strings go in a whole lot easier, but I prefer the concept of the mushroom plugs using the air pressure inside the tire to form a better seal - that and the fact they don't use any glue that has likely dried up (as someone else so wisely noted). I put 12,500 miles on the last rear tire after plugging.
Since that puncture, I've started using Ride On tire sealant but haven't put it to the test, yet - thankfully. http://www.ride-on.com/ Easily available on eBay.
