Is it worth lowering front end for 21" wheel?
Just and observation here (and I will be lowering mine 2" with a progressive monotube kit when my 21 goes on cuz it's cool). Mentioning sitting flat footed because your 6 foot whatever isn't helpful. Inseam measurement would be much more useful. I'm 6'0" and am far from flat footed thanks to my short legs. I only mention it because I read about seat height, etc all the time on this forum.
Lowering the front end alone will not compensate for fender clearance.
You can raise the fender by drilling out (think oblong) the back bolt hole on each side and tilting the fender up from the rear anf tightening.
Another wise tale is to tape a 1/4" thick nut to the center of your new wheel/tire and spin it...it it rubs raise the fender as above, if it doesn't rub you should be ok.
Whomever said that is talking out their a$$. You may have to elongate the rear mounting holes and slightly tilt the fender forward to keep the tire from rubbing but that is not even related to lowering the front end.
Since I've decided to not lower the front end on my bike this is the next thing on my list of things to worry about. I've also read that if you can tape a 1/4" thick nut to the inside of the front fender and spin the wheel without it touching then you should not have to modify the rear bolt holes. I guess that 1/4" is enough room to compensate for "tire sling" at speed. I'm wondering how often it is needed to drill out the holes and raise the fender. Knowing my luck I'll be one of those lucky people that has to drill out the bolt holes!
You will want to tape the nut to the center of the tire and spin, you'll want to check that it clears the entire fender not just one spot where you affixed the nut.
I'd play it safe and go a head and raise the 1/4" or so fender a little to be on the safe side. Also ask the folks you buy your whell package from the should have experience in this area with your particular set-up.
