Cant get stock antenna off??
Old 01-27-2011, 11:46 AM
po1192's Avatar
po1192
po1192 is offline
Default Cant get stock antenna off??
Well , i bought a shorty; it makes sense that the stock doesn't just twist off, so Im not surprised. I took the bag off, where is the safety feature???? Pic would be cool. I got an 06 Street glide. My first bike...super clean....only 2500 miles
Old 01-27-2011, 11:52 AM
vickers1's Avatar
vickers1
vickers1 is offline
It does just screw off. Congrats on your new bike!
Old 01-27-2011, 11:54 AM
mnskip's Avatar
mnskip
mnskip is offline
It does on my 08 also. Maybe 06 is different? I wouldn't think so, but someone else could chime in if so.
Old 01-27-2011, 11:56 AM
Avalanche_Mutt's Avatar
Avalanche_Mutt
Avalanche_Mutt is offline
lefty loosey righty tighty
Old 01-27-2011, 11:58 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
Look very close for a set screw that may have a cap.. If none found, Get a Grip (pun intended) and screw counterclockwise ..
Old 01-27-2011, 12:00 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Wrap some painter tape, etc around the area closest to the mount and use a pair of channel lock pliers "gently" to unscrew it.
Old 01-27-2011, 12:31 PM
po1192's Avatar
po1192
po1192 is offline
Cool...maybe I'll let my wife give it a try!!! lol...
Old 01-28-2011, 05:49 AM
White Knight 04's Avatar
White Knight 04
White Knight 04 is offline
Make sure that the allen screw is loose enough to turn the antenna...
Old 01-28-2011, 06:00 AM
Chaffeekid's Avatar
Chaffeekid
Chaffeekid is offline
Check for the allen screw. You may have to pull up on the rubber cover at the base of the antenna to expose the screw. If you try to unscrew the antenna and the allen screw is set, you will destroy the threads on the post
One of my shorty's that I put on has the allen screw, the other doesn't. The CB side did, (Ultra Classic).
Hope this helps
Ride Safe
Old 01-28-2011, 08:05 AM
skratch's Avatar
skratch
skratch is offline
Received 4,222 Likes on 2,468 Posts
the stock antenna on my 2010 did not have a set screw. the shorty i replaced it with (j&m) does.
Quick Reply: Cant get stock antenna off??
