How to remove warning stickers off painted parts?
Old 02-13-2011, 06:55 AM
trainwreak's Avatar
trainwreak
trainwreak is offline
Default How to remove warning stickers off painted parts?
Just installed new black saddlebag guards which came with the annoying warning stickers. They are not the easy peel off kind either. Peeling is difficult and coming off in small pieces. Does anyone have a good method to remove these?
Old 02-13-2011, 07:03 AM
TexasJR's Avatar
TexasJR
TexasJR is offline
GooBGone....or a lot of HOT SOAPY water......
Old 02-13-2011, 07:08 AM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
Soak a paper towel in Goo Gone and leave it on the exposed adhesive for a few mins and wipe. Repeat several times if necessary.
Old 02-13-2011, 07:19 AM
zam70's Avatar
zam70
zam70 is offline
You'll have to peel/scape the top layer off to expose the adhesive...use some heat to soften it up.
then use wd40 or something similar to dissolve the adhesive
Captain Itch's Avatar
Captain Itch
Captain Itch is offline
Sponsor
A heat gun works well if you have one..
__________________
www.Captain-Itch.com
Old 02-13-2011, 07:22 AM
Jags93's Avatar
Jags93
Jags93 is offline
A powerful hair dryer is enough. That's what I used but my stickers were on chrome. They came off with minimal adhesive remaining. I think your rails are powder coated if they are factory items.
Old 02-13-2011, 07:50 AM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 71,064 Likes on 21,547 Posts
Keep working at it. You'll get it...
Old 02-13-2011, 08:22 AM
eazyduzzit's Avatar
eazyduzzit
eazyduzzit is offline
I use a blow dryer to get the sticker off, then WD-40 or any kind of light oil to get the adhesive.
Old 02-13-2011, 08:27 AM
badknees's Avatar
badknees
badknees is offline
Heat gun and goo gone.
Old 02-13-2011, 08:33 AM
07FLHT's Avatar
07FLHT
07FLHT is offline
Originally Posted by Jags93
A powerful hair dryer is enough. That's what I used but my stickers were on chrome. They came off with minimal adhesive remaining....
+1 Same process worked for me!
Quick Reply: How to remove warning stickers off painted parts?
