Backrest question
Old Mar 15, 2011 | 08:06 PM
firedocs's Avatar
firedocs
Default Backrest question
I have a 2010 Street Glide and I am in the market for a passengers backrest but I am curious as to how these removable ones work. I can see how they fit in one end and the other has some sort of thumb clip. Anyway the difference between the 08 and older vs the 09 and newer looks like a big difference, Does anyone have a pic of a detachable backrest on an 09 or newer that maybe will make sense of how it attaches? If you could remove a saddle bag too would be great. And any info on the luggage racks would be a bonus.
Thanks
Old Mar 15, 2011 | 08:14 PM
Hammer3's Avatar
Hammer3
I have a four up detachable passenger backrest. Works great. I have an 09 street glide!
Old Mar 15, 2011 | 08:36 PM
mannya4's Avatar
mannya4
I also have a 2010 SG. There are 2 options for the backrest mounting. A 2 point dock hardware(only the backrest gets mounted) or the 4 point dock hardware(has mounts for both the backrest and a lugage rack). The backrest itself clips on to the sides near the shock and then to the docking hardware. I don't have any pictures but I could take some tomorrow evening if you are interested.
Old Mar 16, 2011 | 04:01 AM
Phat09flhx's Avatar
Phat09flhx
Yep, had me confused right after I installed my four point docking hardware. Someone came up with the smart idea to design the shocks to be the first mounting point and then the backrest locks to the first set of your docking hardware.
Old Mar 16, 2011 | 04:15 PM
firedocs's Avatar
firedocs
Default backrest
So the the shock mount is where the front on the backrest goes..thus the reason that the 08 an older do not work for the 2010 ( diff. Frame??). And if you want to add a luggage rack you need the 4 point system, correct. It would make sense to go ahead with the 4 point for the future I guess even if you did'nt have a luggage rack huh?
Anyway thanks guys that makes more sense now. Anybody know of a better place to purchase than HD Stealer?
Thanks
Tim
Old Mar 16, 2011 | 06:46 PM
mannya4's Avatar
mannya4
Thanks
Tim
Correct to add a detachable luggage rack you would need the 4pt dock. That is why i went with the 4pt to add the luggage rack down the road. Best place i've found thus far to order HD parts is Zanotti's HD. You can order using the part #s found on harleys website and they are a lot cheaper then msrp on parts! hope this helps and good luck with the backrest.
Old Mar 16, 2011 | 06:54 PM
jeff.georgalas's Avatar
jeff.georgalas
Wow, you ride four up??? How do you fit so many people on your bike? I can't figure out how to do it!!! Just busting your chops!
lkohan7373
Jul 1, 2013 07:29 AM
ggrif
Aug 10, 2011 01:39 PM
LaRider
Dec 11, 2010 06:34 AM
hogrider09
Jul 18, 2010 01:10 AM
mslater741
Apr 16, 2009 07:08 AM
