Inner Primary Housing Removal / Replace Shifter Rod Lever
Old Apr 20, 2011 | 03:56 AM
emwolb's Avatar
emwolb
there's a lot of satisfaction when you get it back together. there are some things that can be sort of intimidating to us who aren't MMI graduates. you gotta figure though, the occ guys were able to assemble bikes, so for us "non mongoloid" types it should be a piece of cake.
Old Apr 20, 2011 | 06:00 AM
carlgrover's Avatar
carlgrover
Buy one of these and you won't have to remove the primary:
http://betterlever.com/index.php
Old Apr 20, 2011 | 06:33 AM
who?me?'s Avatar
who?me?
Replace the inner primary or lip seal as it is called in the manual. $4.65 or so and an easy replace if you have the inner primary off.
Old Apr 20, 2011 | 08:05 AM
dog155's Avatar
dog155
The shifter shaft will pull out without pulling the primary covers.Pull the bolt from the lever the shaft will pull out of the inner primary.
Old Apr 20, 2011 | 11:43 AM
bullet 10's Avatar
bullet 10
I've replaced several of the shifter arms with new. use red lock tite on shifter arm and tranny shaft. I would replace drive belt also with that many miles on it.
Old Apr 20, 2011 | 12:01 PM
Beeracuda's Avatar
Beeracuda
The lever and shaft that we are speaking about is the transmission shift lever, not the foot control. You have to remove the primary to get to it and replace the shaft seal.
Old May 18, 2011 | 04:43 PM
ElectraHead's Avatar
ElectraHead
who's for the better lever? Anyone use these?
Old May 31, 2011 | 10:47 AM
cowboybob56's Avatar
cowboybob56
Wink Get one of these?
The company that make the new and wonderful shift lever is out of stock. Leave your name and number and they will get back to you when they can.
Old Aug 22, 2011 | 08:40 PM
Ghad's Avatar
Ghad
Stage II
Default Better Lever
Can anyone recommend this yet. I pulled the inner primary to replace the stock lever, but the shifter shaft going into the tranny is somewhat stripped. Is it worth the $160?
Thanks!
Old Aug 22, 2011 | 08:53 PM
Beeracuda's Avatar
Beeracuda
I thought mine was stripped too. I put the new lever on and all was good. The local Indy also suggested a tack weld of the lever to the shaft.
