are there EFI autotuners for 2000 bikes w/ MM EFI?
Was thinking about going the cheaper route and use a Dobeck TFI or maybe a PCIII but then in my research I am seeing controllers that autotune - but I can't seem to find one for the older bikes except for the Terminal Velocity 3 which doesn't seem to be getting great reviews. My bike has stock motor (will stay that way) with stock headpipes, SE A/C, V&H basic slip-ons and a stage one flash. I am replacing the V&H with CFR slip-ons (I have Thunder Monster headpipe baffles to try if I need some bottom end torque).
My thinking is this - when I switch out the slip-ons I will need to tune the bike because they are very open pipes....I hear the MM EFI can be hard to tune so I fear that tuning with a PCIII can be costly until the correct map is found and possibly need a dyno tune$$$ - the TFI sounds simple to adjust but has its limitations (may or may not be right for my needs) so, maybe an autotune will be more expensive on the front side but maybe easier to get the proper tune? maybe?
I have a 2000 Road King w/95" engine, MM injection, 510 S&S chain drive cams, true duals with VH Monster Rounds, Stage 1....and a Dobeck TFI....I think the Dobeck is very underrated....my bike went from needing to idle @ 1100 to me having the ability to idle it cleanly @ 700 rpm, with very strong mid range and top end....super easy to tune and can be adjusted for future changes to engine or exhaust....I would recommend the Dobeck
lionsqrne
09-08-2007 09:33 AM
