Swapping out 255's to tw-555 next week....
i did my fm 107 kit in feb and lovin it. due to take it in for the dyno on saturday. but last month I had a rear tire put on and the tech took it for the test ride mentioned clutch was slipping a bit, asked if I had the clutch spring upgraded- no. I didn't think about that at the time of the build (DAMN), so did some research and found its a good idea so I'm doing that too. apparently the engine make a little more hp than the stock clutch can handle. just something for ya'll to consider during your upgrades
I've also got an SE103 with 255s. Once you get your 555s installed I'd like to hear your impressions on what kind of power difference they make through the rev range. Any chance your dealer can do a pre-install dyno run as well so we can compare the sheets?
My current numbers are in my signature. I also have the dyno from a year ago..so yup...I'll have those to compare.
Decided to wait on buying and installing the ever popular FM 107 kit for right now...gotta buy daugther a car for graduation this May...but I am gonna swap out my 255's for the tw-555's.
Ordered the FM pushrods, Woods directional lifters, and the cams. Install scheduled at dealer for Tuesday the 26th. Dealer will also install the new HD oil breathers...maybe that'll help with my blow by.
Looking forward to see if there will be much difference from my current set-up. 103 stgII(255), street port heads with slipons. It'll go in the booth for tuning right after install...
Cant wait...
Cant wait...
