Burnt Oil Smell
Old 04-27-2011, 12:22 PM
tommyj's Avatar
tommyj
tommyj is offline
Default Burnt Oil Smell
I just recently bought a 08 Ultra with 965 miles and when I'm riding 50/60 mph and decelerate I smell something like a hot oil smell. I thought I was getting a leak on a hot pipe but when I park it I can't find a leak nor smell the odor. I can only smell it during decel. Anyone have any maybe's. Other than that, it's beautiful....
Old 04-27-2011, 01:34 PM
tduff's Avatar
tduff
tduff is offline
Not sure about your problem, but I would check for oil around the throttle body and air cleaner, and on the rear cylinder fins.
Old 04-27-2011, 01:55 PM
BackAt5O's Avatar
BackAt5O
BackAt5O is offline
My 07 would do the same thing when it was new. It stopped doing that after the first year or 9000 miles.
Old 04-27-2011, 08:44 PM
getty30188's Avatar
getty30188
getty30188 is offline
check the transmission case cover. I had one that leaked only enough to burn on the exhaust bracket directly under the cover. Never dropped any on the ground
Old 04-27-2011, 09:01 PM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
That's some "LOW" milage. It's still new & maybe it's still got that new bike smell. I had a bike sit for 1yr & had gaskets crack & leak.
Old 04-27-2011, 09:08 PM
fairfax1000's Avatar
fairfax1000
fairfax1000 is offline
You're smelling the exhaust flowback........if it's not leaking, don't worry about it. I get the same thing on my 07 FLHTPI
Old 04-27-2011, 09:17 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Exhaust flowback, very nice. I would have said intake reflux but that would just be silly.
Old 04-27-2011, 09:30 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
An 08 with less than 1k, sounds great, if you still have a problem after 5k I might worry, other than that, good info in previous post.
Old 04-27-2011, 10:44 PM
All Aces's Avatar
All Aces
All Aces is offline
I have the same type smell on my 2010 EGC with about 6k on it now. It started at about 2-3K. Not leaking or using oil but when I stop and engine is hot it just smells like burnt oil.
Old 04-27-2011, 11:29 PM
Bingee's Avatar
Bingee
Bingee is offline
Sometimes a drop or two of oil will fall from the air cleaner and land directly on the hot exhaust pipe but behind the shield. You can't see it. But you can smell it. Not a problem though.
Quick Reply: Burnt Oil Smell
